Heat at my feet!
Old Feb 17, 2010 | 06:02 PM
buzz350's Avatar
buzz350
Default Heat at my feet!
Am new to this site so hope I am posting in correct area
Have just purchased 2003 350Z coupe and am getting radiant heat via centre console vents near my feet. Have read a few threads with explainations of exhaust pipe heat, engine too close etc etc but havent been able to find how to fix the problem. Can someone point me in the right direction. I dont know if it is a design " fault" or vent isn't shutting properly ( changing vent control positions doesnt eliminate it) or what??? Went to local Nissan Dealer and they seemed to shrug off as due to being a " high performance sports car"....hmmmmmmmmm. I dont want to put up with it, if it can be fixed. I live in South Australia which is pretty hot at the best of times without having additional heat produced while you are driving!!
PS I know someone will mention that there is an air conditioner fitted, why not use it. I dont believe it is practical to drive with window open to enjoy the cool fresh air and have the AC on your feet to get rid of the heat!
Thanks
Buzz
Old Feb 17, 2010 | 07:29 PM
SoldzMyZ's Avatar
SoldzMyZ
normal. i too have that since the transmission is basically over that area.
Old Feb 17, 2010 | 07:30 PM
SatchScream's Avatar
SatchScream
Just don't put your feet down there duuuuhhhhhh.
Old Feb 17, 2010 | 07:43 PM
The transmission hump and floor above the catalytic converter is warm. That is just the way it is.
Old Feb 17, 2010 | 07:50 PM
sportbiketed's Avatar
sportbiketed
Yup its normal on the Z. Kinda sucks when I drive barefoot in the summer, my heel gets nice and toasty.
Old Feb 18, 2010 | 01:36 AM
SA Z-boi's Avatar
SA Z-boi
Never really had that problem. If its the vents I would turn the climate **** to 60 so you dont get any hot air coming in from the engine bay
Old Feb 18, 2010 | 06:03 AM
lameophucnuckle's Avatar
lameophucnuckle
My 04.5 does it too. I usually ride with the a/c on vent/floor and it seems to keep my feet from sweating. ha.
I think it's normal, you could possible pull the console and carpet and put some heat resistant material or something to help. I don't think it'll ever totally eliminate the issue but it might help... and probably cut some road noise as well.
m
Old Feb 18, 2010 | 06:11 AM
zerafian's Avatar
zerafian
Iv never heard of this issue but it sounds like your not the only one...I suppose I wouldnt worry.
I would suggest not going back to the dealership though. It sounds like they dont know so they'll end up digging around in your car and charging you for it.
Old Feb 18, 2010 | 07:15 AM
PerfZ's Avatar
PerfZ
Yep, normal. Annoys me that on a somewhat cool spring/fall day, I still get warm air even turning the temp control to 60. I've never read any posts where someone found a good way to insulate that area though or any other solution. Just one of those little bugs you have to put up with in order to enjoy the rest of the car.
Old Feb 18, 2010 | 07:31 AM
VO...'s Avatar
VO...
Administrator
It's normal...
Old Feb 18, 2010 | 11:10 AM
buzz350's Avatar
buzz350
What I cant understand is why some Zs have a problem and some dont?
I have 3 questions.
1)Has Nissan fixed the problem with the later models and if so, can a retro fit be done to sort out the earlier models ( mine is a 2003)
2)Is the issue an open vent bringing hot air in or is heat soaking thru the bodywork
3)If there are so many intelligent people driving Zs, why hasnt someone sorted it out yet?
Any answers?????
Buzz
Old Feb 18, 2010 | 11:17 AM
Phantom_Z's Avatar
Phantom_Z
'08 here and have the same problem once in a while. I always turn the dial to 60/windshield and it helps a lot.
Old Feb 18, 2010 | 07:09 PM
duro78's Avatar
duro78
never noticed it
Old Feb 19, 2010 | 05:19 AM
silvertouringz's Avatar
silvertouringz
04.5 here, yeap it gets pretty hot down there
Old Feb 19, 2010 | 05:51 AM
BGuess's Avatar
BGuess
yep its normal. noticed this when i first got my 03
no big deal
Old Feb 19, 2010 | 06:58 AM
britalia's Avatar
britalia
I have an 06, and yep, thats par for the course.
Old Feb 19, 2010 | 04:57 PM
glenns280's Avatar
glenns280
06 same here gets hot
Old Feb 19, 2010 | 10:54 PM
I have 3 questions.
Any answers?????
Buzz
Because you have no objective data:
Ambient temperature?
Time motor has been running?
Temperature of transmission hump and floor?
Speed?
All we have is warm, kind of warm and hot. All terribly subjective.
Old Feb 19, 2010 | 10:55 PM
Motormouth's Avatar
Motormouth
Thanks
Buzz
best first post ever
best first sentence of first post ever
Old Feb 20, 2010 | 09:26 AM
2boosted4u's Avatar
2boosted4u
get test pipes you wont have to worry about the cats heating the floor up
