Tachometer needle bounces why?
Old Mar 17, 2010 | 03:49 PM
Spork's Avatar
Spork
Tachometer gremlins
Old Mar 17, 2010 | 08:13 PM
nismonian's Avatar
nismonian
i think i know what your talking about op. dont sweat it
Old Mar 17, 2010 | 08:22 PM
TheFarmer's Avatar
TheFarmer
Kewl.
Old Mar 18, 2010 | 12:29 AM
itsjiggajames's Avatar
itsjiggajames
I think I know what he's talking about too. For instance, every gear I shift into the tach bounces at the designated rpms +/- 250-500 rpms.. for instance, if shifting from 1st to 2nd lands me at 3k, the rpms would jump around from 2750-3250 for a split second then stop at 3k.. same with if I blip the throttle really quickly while in gear, the tach needle would bounce above and below the correct rpm.
I drove an 08 Z and it did not do this; nor any other manual car I've driven for that matter
Old Mar 18, 2010 | 05:01 AM
CS350Z86's Avatar
CS350Z86
This is exactly what is happening to me. Good job. Someone knows what i'm talking about lol. Guess it's normal for these cars or certain years.
Old Mar 18, 2010 | 05:20 AM
PerfZ's Avatar
PerfZ
It's not the certain car or the certain year - it is part of engine/transmission physics. But I am still not understanding the "rough road" part of the OP
clar·i·ty
   /ˈklćrɪti/ Show Spelled[klar-i-tee] Show IPA
–noun
1.
clearness or lucidity as to perception or understanding; freedom from indistinctness or ambiguity.
Old Mar 18, 2010 | 10:26 AM
MarvinMartian's Avatar
MarvinMartian
Turn down the music.
Old Mar 18, 2010 | 02:41 PM
itsjiggajames
clar·i·ty
–noun
1.
not that I doubt your reasoning on why it bounces, but why do some Z's do it and other don't? I think it is more of a tach issue.
Old Mar 18, 2010 | 04:41 PM
xthejokerx's Avatar
xthejokerx
You are aware that the tachometer is reflecting engine speed, correct? And you are aware that if you hit the gas the engine speed will increase, correct? It is pretty much impossible to get the engine speed to 250 without stalling out. And if letting the clutch out makes your car jerk, you need some training on driving a MT. I'm having a very difficult time understanding your "problem". So I have to ask - how old are you?
Before asking how old the OP is, you should re-read his question. Seems like you jumped to the conclucion, and YOU'RE the one not understanding what he's trying to ask.
Old Mar 18, 2010 | 05:14 PM
AML225's Avatar
AML225
I have an '08 6sp MT and mine DEFINITELY does not do this. (If that helps at all.)
Old Mar 18, 2010 | 10:48 PM
tziller1225's Avatar
tziller1225
mine does not either..hm...interesting..maybe u r not timing right?..steping on accelerator before engagement?.
Old Mar 19, 2010 | 08:32 AM
slopefunk's Avatar
slopefunk
I have a 05 base model. Mine is also doing this. I have not made any attempts to really isolate this issue. Since I have no jerking or harsh engagement issue, and smooth acceleration I chalked it up as a gauge defect rather than speed sensor.
Old Mar 19, 2010 | 09:19 AM
Brrcats's Avatar
Brrcats
that was an amazing episode
Old Mar 20, 2010 | 08:00 AM
PerfZ's Avatar
PerfZ
My apologies for not understanding a post that has the grammar of a 10 year old.
Old Mar 20, 2010 | 07:48 PM
Manjot's Avatar
Manjot
OP- I think I know what you're referring to. Mine does that as well, mostly after I've floored it or gotten close to redline. The best way to describe it is that the tachnometer needle becomes 'extra sensitive' and starts hesitating.
Old Mar 21, 2010 | 09:02 AM
rnalecz's Avatar
rnalecz
OP - had a 06 that did this. When in gear I give it gas and it would bounce up and down, not sure how it works, but i'm sure it can be fixed. I would go to the dealer and they should know. What mine also did was it would get stuck too for about 10 seconds. Sitting at a light and it would stay at 700 rpm and after I drive off it still stayed at 700 while I'm shifting through the gears. About 10 seconds later it would slowly slug back up to working condition. This only happened probably 5 times, but I dont need that gauge anyway, I know where my red line is Now I have a 07 but it does not do this tho.
05UltraYellow
Sep 24, 2015 05:41 AM
Darkspy
Sep 7, 2015 09:09 PM
Killermove
Jun 14, 2011 07:38 PM
themyst
Oct 27, 2002 04:48 AM
3rdpower
Jul 15, 2002 04:17 AM
