Stock Dyno results - over 315HP?
Old Nov 7, 2003 | 11:22 AM
igor@af's Avatar
igor@af
Default Stock Dyno results - over 315HP?
Hey guys,
Haven't been here in a while...
I dynoed my car at Horse Power House in Lexington, KY the other day and we got some funky results.
It was done on a Mustang AWD Dyno (MD-AWD-500-SE ) which is an EDDY current dyno.
I was wondering if anyone else had dynoed theirs on an EDDY current dyno so we can compare the results.
As you can see, there is absolutely no HP drop. We took it to 6500RPM and stopped, due to the rev limiter.
What do you guys think?
I'd love to hear some analysis from people that are familiar with EDDY current dynos as I am told these results are very high for a stock Z, not to mention the HP does not drop anywhere at the top.
Old Nov 7, 2003 | 11:24 AM
FairladyZ's Avatar
FairladyZ
What are the results, and what gear did you dyno in? Believe it or not mustang dynos, dyno lower than a dynojet. (not as accurate?)
Old Nov 7, 2003 | 11:26 AM
igor@af's Avatar
igor@af
We did it in 5th, as it's 1:1.
Actually, I am told that EDDY is more accurate than inertial.
Old Nov 7, 2003 | 11:30 AM
FairladyZ's Avatar
FairladyZ
huh, that goes against what I am used to. How exactly was it done? I was gonna say you could have 240+ on a dynojet. Thats why I hate dynos....Its how your car performs on the street.
Old Nov 7, 2003 | 11:38 AM
igor@af's Avatar
igor@af
I was offered an estimated conversion formula to figure out what the car is producing at the crank:
229.6 * 1.17 (difference between EDDY current and inertial dynos) / 0.85 (15% drivetrain loss) which comes out to around 316 hp. How accurate that is however, I am not sure.
But, we also dynoed a 2000 Eclipse GT (3.0 liter V6) that is rated at 210hp stock. This one had 157.5hp but had the following mods:
AEM CAI, Unorthodox underdrive pulley, Fidanza flywheel, Magnagor plug wires, and Magnaflow muffler.
By applying the same formula:
157.5 * 1.17 / 0.85 we arrive at around 220hp, which is a reasonable 10hp gain from the mods listed. However, the Eclipse is obviously FWD and so drivetrain loss is probably less.
Old Nov 7, 2003 | 12:37 PM
FairladyZ's Avatar
FairladyZ
You cant always rely on 15%. That is just an easy "universal" way to figure hp #'s without a dyno. But I see what you are saying.
Old Nov 7, 2003 | 02:30 PM
igor@af's Avatar
igor@af
yes, this is in no way accurate, but I still would think is a somewhat good estimate.
So has anyone else dynoed their Z on an EDDY dyno?
Old Nov 7, 2003 | 02:55 PM
D'oh's Avatar
D'oh
I haven't dyno'd my Z, but based on the other dyno plots I've seen, yours look fine.
The torque curve looks the same as the others, with a slight rise until 4800, then a noticeable dip around 5100 and then a steady decline to redline. Yours seems to look maybe a bit too good on the top end compared to most others, but the results don't seem to be too far off. I'd say that you should just remember to go back to that same dyno when you get mods so you can make a good comparison.
-D'oh!
Old Nov 7, 2003 | 02:56 PM
igor@af's Avatar
igor@af
Fellow Brickyard-er! How great
Old Nov 7, 2003 | 05:35 PM
igor@af's Avatar
igor@af
Old Nov 7, 2003 | 09:40 PM
D'oh's Avatar
D'oh
mmmm.....Brickyard....
-D'oh!
Old Nov 10, 2003 | 01:48 PM
350G's Avatar
350G
Heh, heh . . . my old white eclipse LIVES!!! I hope Danny is treating it well
Gary
Old Nov 15, 2003 | 08:27 AM
igor@af's Avatar
igor@af
As per this experiment: http://www.sportrider.com/tech/146_0102_dyno/
"Our TL1000R test unit (June 2000) measured 102.1 horsepower on a Factory Pro eddy current dyno, and 118.9 horsepower on a Dynojet inertia dyno. According to Salvisberg, Factory Pro eddy current dynos read 14 to 15 percent lower than say, a Dynojet inertia dynamometer in the 90 to 100 horsepower range, with even more difference at higher power levels."
But on the other hand, I have found topics here on the forums that state the opposite - that Mustang Dynos generated larger numbers than inertial dynos.
Can somebody clarify this for me? I am still actively trying to research this topic but do not have much solid info, due to various contradictions that I have found.
sales@czp
Sep 23, 2019 03:30 PM
