5at Dyno Results
I dyno'd my 5AT with only 2K miles on it and my numbers were consitent with the other 5AT that dyno'd the same day. You can see my dyno graphs on my web page. I can't post the images from work but you can see them here.
http://home.comcast.net/~z327/ground.htm
so did you dyno it in manu-matic mode and take it up to fourth gear? or did you leave it in automatic and wait for it to kick into fourth gear and then take through the rpms slowly, so it wouldnt go into 5th gear? i really would like to know. ive asked at least two people and what they told me wasnt very descriptive. i redyoned today in manu-matic and got the same 4th gear results. i would greatly appreciate any reply that could tell me blow by blow how you did it, because right now i'm pretty much clueless.
I've dyno'd 9 pulls on two occasions all with similar results.
TCS was turned off. If you have VDC it should be turned off as well. AC off of course.
Car was put into manual shift mode and shifted from 1, 2, 3 and to 4th gear and then pushed to redline.
ok let me get this straight.. The 350Z AT only dynos 215 HP? isnt that a 25% loss?
I know manuals on average loose about 17% and i would think automatics would loose about 20-22% at the MAX...
Why are the automatics loosing so much HP to the wheel? Is this normal?
I guess the Torque converter is never totally locked up and the fluids keep compressing. but 215 HP sound right with a 6mt at about 20 more 235+
Hopefully I'll dyno tomarrow at Stillen at 250+whp and if I make it, I'll tell you what I had to do to get it...and in I don't its more mods....
Can you post your dyno when get it done?
by the way, it was nice chating with you the other day at Performance Nissan.
Didn't make it at Stillen 245 whp in 3rd but no A/F so I'm going back to Powertrain to retest for the info I need to reset the ECU. Running out of options to get the 5hp I want. Won't go with a ugly plenum or cams but might now consider the best header available. Well see after the retest and adjustments are made.
mr.twisted, didn't you get 243/236 without the ECU? I'd expect you to get more than 2hp from a $600 ecu program.
I think you may hit your magic 260 on powertrain's dyno. when do you plan to run it again?
Did it this afternoon about 1pm It was clear and sunny like when we all did it.
With the same setup as Stillen but without rain.
252.6HP 243.2 tq run 16
251.9 HP 243.9 tq Run 17 Made power all the way up to 6350 thun drops I'm there and happy for now. A/f is perfect
13.0 at 5500, 12.9at 5750, 13.0 at 6000,12.9 at 6250 12.9at 6500, 12.8at 6750 12.8 at 7000 Techno Square tuned it to perfection.. Forgot to tell you thats with pulleys and the Technosquare.
The pulleys and Perfect tuning have got to share the 10.2 HP and the 5.5 lbs of TQ
Nice! So you got ~22rwhp/14rwtq with highflow cats, pulley, and ecu.
RT cats @ +13/+6 gain
Pulley + ECU @ +10/+5 gain
Considering the parasitic losses of AT, thats pretty good gains. Congrats!
Can't wait to see how jason@performance scores tonight with his RT cats. I'm so tempted to get these now.
nice!!1 looks like you can garage/give that baby for a show car and get to work on your track model!
I think some people are not too sure about how a dyno works here. Let me take an example of dynoing a car in 3rd gear vs. 4th gear.
3rd gear ratio: 1.472
4th gear ratio: 1.000
When you dyno, you might think that since 3rd gear has a higher ratio, you will dyno a much higher number in 3rd gear. However that is not the case. I am speaking from experience with a Dynojey dynometer. I would think that other dynos are the same but I cannot say that for certain.
The drums factor in gear ratio by calculating the speed of the wheels to the speed of the tranny and give you the results as if you are 1:1.
Technically you can dyno in any gear and they should give you pretty much the same numbers (+/- 5hp/tq due to heat and whatnot).
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
