Anybody using non-ethanol gasoline?
Old 03-22-2011, 10:21 PM
winchman
winchman's Avatar
Default Anybody using non-ethanol gasoline?
There's a station in town selling gasoline they claim doesn't contain ethanol. The price is about 12 cents per gallon higher than stations selling gasoline marked "up to 10% ethanol". It's a small un-branded station, so I have no idea where they're getting the gas.
Does it make sense to spend the extra change for non-ethanol?
I tend to stay away from stations like that. Many years ago they had a reputation for selling crappy gas, but it's probably all crappy nowadays.
Old 03-22-2011, 11:21 PM
n7zfe
n7zfe's Avatar
Default Good idea to use no-ethanol in certain situations
My neighbor has a 50's Chevy Nomad and a 57 Chevy pickup. He requires the no-ethanol gas because he says it doesn't corrode old seals and hoses. Modern vehicles should have no problem.
I usually don't care most of the time, but I like to patronize the local no-ethanol stations here in Boise occasionally just to support them. I like having the option. The price difference is a little less than what the OP is reporting.
Ethanol also attracts water. I store my 350Z during the winter, and make sure I fill it up with no-ethanol (plus Stabil of course) when I put it away in early November.
You will also get better miles per gallon with no-ethanol. Ethanol produces fewer BTUs of energy per gallon than gasoline during combustion, so it takes more fuel to go somewhere. I doubt the improvement is enough to make up for the difference in price the OP is seeing. I wonder what MPG the E85 users are seeing.
I've been told that the ethanol is mixed in with the gasoline when they're filling up the delivery truck at the terminal before taking it to the gas station. I don't believe ethanol is compatible with pipelines, so they can't mix at the refinery. They have to ship it by truck. If anyone has better info about this, I'd be interested.
Old 03-23-2011, 04:51 AM
VQ35deMax
VQ35deMax's Avatar
In my area, the price of gas with ethanol and without it is the same. So I get gas without ethanol.
Old 03-23-2011, 06:41 AM
Scooped350Z
Scooped350Z's Avatar
I thought 92 and 93 octane does not contain ethanol.
Old 03-23-2011, 06:43 AM
plumpzz
plumpzz's Avatar
There would be about a 3% reduction in mpg.
Old 03-23-2011, 07:47 AM
Dealsgap
Dealsgap's Avatar
Default stations in your area using non-ethanol
Its getting to the point where you can't find stations like this. The below website might help. Just put your particular state after "=".
As stated, ethanol is harder on older cars. I recently had to replace my injectors (@ $150.00 a piece) on my old 94 Maxima because we moved and I started using a different brand of gas unknowingly with higher ethanol levels.
My mechanic (which has always worked on my Maxima) told me it was because of the ethanol and the "older injectors" not being as "compatible".
http://pure-gas.org/index.jsp?stateprov=VA
Old 03-23-2011, 09:16 AM
dfresh713
Master
dfresh713's Avatar
I wish they would move back to non-ethanol. In reality it's making gas prices higher.
Old 03-23-2011, 09:49 AM
n7zfe
n7zfe's Avatar
Default Even premium can contain ethanol
As I understand it, adding ethanol actually improves the octane rating.
Old 03-23-2011, 12:47 PM
doshoru
doshoru's Avatar
this.
Old 03-23-2011, 07:19 PM
dcastillo819
dcastillo819's Avatar
Im running 93 octane with no ethanol from the shell gas station. But I will never purchase ethanol ever again. Used it once because I had to, and only put 10 dollars to get me to the next gas station on my 93 rx7 and couldn't go past 5k rpm's and it would smoke like a frieght train when I would shift gears. I have had a bad experiance with it and never again.
Old 04-02-2011, 06:39 AM
The_Laughing_Man
The_Laughing_Man's Avatar
sed
Old 04-02-2011, 02:43 PM
gregom
gregom's Avatar
I'm lucky I have two fuel stations that sell non-eth here in Boise on my route to and from work. I don't have my Z fixed up yet but my 83 RX7 runs like crap on E90/E85 so I pretty much have to run non-eth or it has all kinds of problems.
Old 04-02-2011, 02:50 PM
danisr1
Sleeps in 350Z
danisr1's Avatar
Ethanol also eats up outboard boat motors, not a fan
grey00lustre
04-29-2011 03:31 PM
ZSpinZ
04-12-2008 01:05 PM
mgl
Northern California
10-26-2005 11:12 AM
bobS
11-12-2004 03:49 PM
Quick Reply: Anybody using non-ethanol gasoline?
