Rev Limiter question
Old Sep 6, 2002 | 08:31 AM
J350's Avatar
J350
Question Rev Limiter question
I won't be able to get my manual to read up more on this until later tonight, so thought I would ask some of you knowledgable guys in the meantime:
If I set the Rev Limiter to 4000, I should get a red indicator light blinking as it approaches 4000 & it should stay lit when it hits & exceeds 4000 RPM right? I've read a few posts where people that exceeded the set Rev limit had the engine just stop right there, but I've gone past it a few times w/o any slow down, so I'm wondering if there is something wrong, b/c mine is acting more like a Rev Reminder since it isn't actually limiting anything.
Anyone else notice this, or am I completely misunderstanding something here? I'm guessing that while skimming through some threads, i may have misread posts & the engine cutoff when they red-lined & didn't shift to a higher gear.
thanks,
J
btw, it was set to 2000 when I first got it & until I got around to setting it to 4000 (per break-in reccomendations) I went up to around 4000 w/o the engine cutting off...
Old Sep 6, 2002 | 08:34 AM
westpak's Avatar
westpak
SFZCC
The setting used on the trip computer is just to set the upshift light and not a rev limiter, the only rev limiter is at the redline, I think around 6500?? At that limiter is the only time the engine will cut off not at the shift light setting.
Old Sep 6, 2002 | 09:10 AM
z350z's Avatar
z350z
Charter Member #13
Right, all you are setting is when the light blinks. It will start flashing at 500RPM below the setting, and light steadily at the setting and above.
The rev-limiter is not settable: it's just a self-defense mechanism for the engine so you can't rev it to death! It seems to kick in above 6700, but I didn't see the exact revs. When the rev limiter kicks in, it totally cuts power and it's not subtle at all; you kind of want to avoid it. That's why the light is so great! I have mine to set to 6500 now, but I had it set to 5000 during break-in.
Old Sep 6, 2002 | 09:45 AM
J350's Avatar
J350
thanks for clarifying guys!
just wanted to confirm that there wasn't anything wrong with the computer.
issyz
Jul 2, 2017 03:04 PM
