Need Help! Got screwed by the dealer!
Old Jul 6, 2011 | 02:54 PM
hooks4feet's Avatar
hooks4feet
Default Need Help! Got screwed by the dealer!
I bought a 07 350z off the NorthPoint Nissan lot in Little Rock last July. When I bought it (certified by Nissan) it had 24k and change on the odometer. I've had it less than a year and it only has 26k and change on the odometer. Needless to say, I don't drive much and when I do I baby it.
Anyway, last week suddenly I had no clutch at all. I pressed the pedal to the floor but wouldn't engage. Managed to pull over and hit the ebrake to kill the motor. Got it towed after doing a bit of research and finding out there was a slave cylinder recall on that year. All the symptoms matched exactly what was happening with my ride.
Next day Nissan calls and says that the clutch and pressure plate are both completely useless and need replacing. Naturally this is also not covered under warranty due to "normal wear and tear." I've even got an extended warranty that the salesman said would cover crap like this.
I refuse to pay for this and have filed a claim with the regional office. Having a clutch go out with a quarter of a century on the odometer is unacceptable, no matter how the previous driver rode that car. What's worse is that I haven't even gotten to oil change mileage and it shut down on me. If that was an issue that existed before I bought that car it should have been fixed.
No matter who I talk to, I get the same "normal wear and tear" routine and get told it does no use to argue. What the hell do I do here?
Old Jul 6, 2011 | 03:06 PM
Italianjoe1's Avatar
Italianjoe1
Generally speaking, wear items are NOT covered under any sort of warranty, factory or extended. Usually an OEM will cover unreasonable wear (brake pads under 10K miles or something extreme like that), but it is on a case by case basis and at dealership discretion, not warranty per-se. I'm currently a service writer at a honda dealership and clutch/brake warranty is figured at 8K miles, anything more than that requires district manager approval and is considered goodwill.
Sad to say, but you are most likely outta luck.
Old Jul 6, 2011 | 03:07 PM
Wu-Watt's Avatar
Wu-Watt
Clutch=Your problem
Old Jul 6, 2011 | 03:10 PM
Blu_Blur's Avatar
Blu_Blur
24K and change? 26K and change?
Quarter century on the odometer?
lol
And have they made a decision?
Old Jul 6, 2011 | 03:11 PM
Ruthless18x's Avatar
Ruthless18x
Unfortunately things like that happen. Just take care of it and move on.
Old Jul 6, 2011 | 03:34 PM
Jeff92se's Avatar
Jeff92se
Make sure they save the parts they replace so you can inspect them for yourself. If the pressure plate is blued and the clutch disk material is worn down, well there you go. The previous owner must have rode the car hard. If the parts are in great shape, then you have a case to take to Nissan corporate and state your case for a refund.
Old Jul 6, 2011 | 03:55 PM
winchman's Avatar
winchman
They probably keep a set of really crappy worn-out clutch parts in the back room to show customers like you. Then they rebuild the clutch hydraulics for $15 in parts, leave your hardly-worn clutch in place, and send you on your way with a bill for $800.
Old Jul 6, 2011 | 04:10 PM
hooks4feet's Avatar
hooks4feet
Yeah right. They are quoting me $1600 bucks. I understand that wear on that part happens, but it should have been taken care of before selling it as a certified used car on their lot.
Old Jul 6, 2011 | 04:11 PM
hooks4feet's Avatar
hooks4feet
Said they'd let me know by Friday.
Old Jul 6, 2011 | 04:15 PM
verdict.'s Avatar
verdict.
+1
Used cars are usually sold "as is", but good luck.
Old Jul 6, 2011 | 05:05 PM
henwhee's Avatar
henwhee
sad to hear op, but goodluck!
Old Jul 6, 2011 | 07:42 PM
Well we have until Friday before you set the dealership on fire.
Old Jul 6, 2011 | 08:03 PM
drivessidewayz's Avatar
drivessidewayz
They're trying to squeeze more out of you; it's a really common thing. Tell them to replace/rebuild the warrantied part and then go from there. The master/slave cylinders have nothing to do with the clutch/flywheel, so it's not like it's extra labor.
Old Jul 6, 2011 | 08:31 PM
sportbiketed's Avatar
sportbiketed
Ugh dude just drop it, warranties do not cover wear items. Just have them replace the slave cylinder under warranty, if that doesn't fix it then just man up and pay to have the clutch replaced.
Old Jul 6, 2011 | 09:00 PM
terrasmak's Avatar
^^ This
Mention supplying your own parts and watch them tap dance, they want to bend you over for the price on the clutch , disk and flywheel. $1600, and their cost is probably $600 then it is roughly 1/2 hour extra to swap them once the trans is out for the slave cylinder. My dealer swapped my clutch and flywheel for free when they warrentied my trans.
Old Jul 7, 2011 | 04:06 AM
NZMOWND's Avatar
NZMOWND
better question is y the hell havent u been at any of our local meets??? Also North Point Nissan sucks *** when it comes to servicing, i always go to NLR nissan to have all my stuff done...Where do u live becuz if its now way out of your way i would recommend going there next time, also see if u can find a shop instead of a stealership to do the work not covered under warranty!
Check out this thread for info on meets...what color is your Z??
https://my350z.com/forum/south-centr...areas-190.html
Old Jul 7, 2011 | 08:16 AM
BoomerZ33's Avatar
BoomerZ33
+1 on wear parts not being covered. if all else fails take it to another performance shop to finish the job. labor rates are ridiculous at the stealership.
Old Jul 7, 2011 | 09:10 AM
pcressey's Avatar
pcressey
I also think you are fighting an uphill battle. I would recommend spending your time (time = $) on purchasing an aftermarket clutch kit and flywheel from one of our vendors... you can get the whole package for under $1,000 shipped... ACT or JWT.
Old Jul 7, 2011 | 09:24 AM
konaforever's Avatar
konaforever
Had the same issue last year on my 2008. Slave cylinder was replaced for free due to the recall. Even got a free rental.
Clutch and pressure plate is a different issue. Not sure why yours needs to be replaced so soon.
