Complete stock 2005 350z, looking for upgrade path
Depending on your budget
1. Plenum spacer
2. Upgrade your Intake (3.5” intake) and if you have the funds upgrade to the 76mm throttle body
3. Cat back exhaust
4. 3.9 gearing differential
to maximize the efficiency of those mods, highly recommend a tune. You will definitely require a tune if you go with a 3.5” Intake. Or you can opt for a 3” intake setup and your car will run fine without a tune unlike a 3.5”
a tune will bring happiness to your life
1. Plenum spacer
3. Cat back exhaust
For anyone else searching in the future:
If you plan on doing any track events.
Leave the motor alone, it will last longer.
1. Brake Pads
2. S.S. Brake Lines
3. Motul 600 fluid
4. Many track days under your belt
5 Oil Cooler
6. Larger Power Steering Cooler
7. Suspension.
8. Exhaust
1. Brake Pads
2. S.S. Brake Lines
3. Motul 600 fluid
5 Oil Cooler
7. Suspension.
8. Exhaust
