Starting to get disenchanted with the Z
Old Oct 14, 2012 | 05:20 PM
hellman_x's Avatar
hellman_x
Originally Posted by Cux350z
where do you buy your headlight parts?
You can mount all belts with the vortech mounted. I used to remove the cog belt with the bracket on as well as the main drive and ac belts.
I used the links in the DIY. I can assure you it is impossible, I have a rev up and it is different from the regular DE I suppose.
https://my350z.com/forum/body-interi...eadlights.html
Old Oct 15, 2012 | 09:42 AM
kingdom's Avatar
kingdom
cool car
Old Oct 15, 2012 | 10:57 AM
hellman_x's Avatar
hellman_x
Called Vortech today, somehow my car has the wrong pulley. It's a 3.33 on there, it's supposed to be a 3.12. I don't know how I got the wrong pulley.
Old Oct 24, 2012 | 06:31 PM
WSchli1672's Avatar
WSchli1672
Too bad with the headaches, oil leak. I had an oil leak before, took it to ZCarGarage and fixed. Never had a problem since. Vortech works great, also was upgraded by ZCarGarage (ZCargarage.com), which does all Z's, G'z, GTR's etc. Shop has 370Z and GTR and runs on the track. Has 491hp, no problems at all. I was also pretty stressed out when I had a oil leak problem, but Rob really took care of it for me. I was same though, bought stock and then $$$$$$ later, a whole different feeling. Love it.
Old Oct 24, 2012 | 07:11 PM
hellman_x's Avatar
hellman_x
Well I changed the seals and no more leaks but now it's running rich like crazy. Cleaned the MAF, no difference. Car is in the shop right now, just waiting on prognosis. The drive there sucked so much ***, the shop is about an hour and a half away and I had a headache by the time I got there because my car smelled like a lawnmower. At least if I get it retuned it'll only be 450.
Old Oct 25, 2012 | 04:35 AM
Nismo350z#0310's Avatar
Nismo350z#0310
I'm not trying to troll but just from my point of view it sounds like the root of the problems is you're either not very good at DIY or you're forgetting things often when doing them. Either way I hate you're not sure of stinking with the 350z. Hate to lose another Z person in the community.
Old Oct 25, 2012 | 10:48 AM
hellman_x's Avatar
hellman_x
Is your car FI? A reputable shop did the install and tune, it ran fine for a year a half of daily driving. About 15k miles and the blower leaked oil. Not sure if you have ever done any modifications to your car personally but the engine bay is not fun to deal with. There's a reason shops take out the engine to do supercharger and turbo installs. Do you have a compressor? Impact gun? A 3 jaw pulley removal tool? Offset wrenches? No? Goodluck doing what I did than. I'm just going turn this car into a weekend car and get older WRX or something similar as a DD.
Old Oct 25, 2012 | 11:15 AM
Nismo350z#0310
Hey, like I said, I'm not trying to troll you. I have installed a few things on my car- coilovers, brake rotors, pads, SS lines, fluid, sway bars, camber arms and toe arms, exhaust. I do have an air compressor, impact gun, welder- steel and aluminum, saws all, offset wrenches and and a million other air tools at my disposal though, lol. Not hit the FI yet, although I'm extremely close to it. Got the cash to liquidate but I'm struggling to light the match and watch it burn. I'll cave by early next year though when I've built enough of a cushion to feel ok about liquidating $17k of my savings.
Glad you're sticking with us though man. Z car people gotta stick together.
Old Oct 25, 2012 | 01:52 PM
hellman_x's Avatar
hellman_x
My suggestion is stay stock unless you have backup, goodluck.
Old Oct 26, 2012 | 03:22 AM
Nismo350z#0310
Yeah, the Z isn't my DD anymore. As of now I'm trying to get it to be more of a garage queen. Seeing if I can get it to hold it's value, and to stay in good condition.
Old Oct 26, 2012 | 07:42 AM
BoomerZ33's Avatar
BoomerZ33
just part it out already and end the misery
Old Oct 26, 2012 | 10:29 AM
vert-z's Avatar
vert-z
I just would like to know what type on plenum that is. I want it.
Old Oct 26, 2012 | 10:42 AM
hellman_x's Avatar
hellman_x
I am actually considering, but it is already getting retuned right now. Since I put on the correct 3.12 pulley that is supposed to come with the rev up engine I got 2 more pounds of boost, that should quite a bit more hp. I'll get the results tomorrow and just park it for a while.
Old Oct 26, 2012 | 10:43 AM
hellman_x's Avatar
hellman_x
Cosworth intake manifold.
Old Oct 26, 2012 | 11:09 AM
iideadeyeii's Avatar
iideadeyeii
How much lighter is the CF hatch versus the stock hatch?
Old Oct 26, 2012 | 07:51 PM
hellman_x's Avatar
hellman_x
It is quite a bit lighter, not really sure by how much however. I only use one hatch shock and it holds it up no problem.
Old Oct 27, 2012 | 02:42 PM
BoomerZ33's Avatar
BoomerZ33
plus or minus 50 lbs probably. it really makes a difference.
Old Oct 27, 2012 | 08:20 PM
  #38
hellman_x's Avatar
hellman_x
Finally got my car back today with 2lbs extra boost. Don't even get a chance to really push her hard with hurricane coming tomorrow and going on vacation Monday for a month.
Original install:
Retune:
Old Oct 27, 2012 | 09:50 PM
  #39
supraturboman's Avatar
supraturboman
Very nice gain. It should feel completely different.
Old Oct 27, 2012 | 11:46 PM
  #40
MaelstrØm's Avatar
MaelstrØm
How much power does the non-FI stroker kit get you?
