About to purchase 2005 35th Anniversary Edition
. You do realize all the oil is being thrown around and all up the dipstick. Oil in in the system and passages and needs to drain down to the oil pan for at least couple hours before you check. I 100% guarantee you the oil will be all over the dipstick if you check when you are gassing since you have been driving it. Best to check on a 100% level surface and overnight. That is an accurate reading and everything else is 100% FALSE and waste of time. keep checking that oil every time you gas and don't bother with tire pressure while gassing.
lolz......seriously dood. Go read the damn owners manual. You check your oil every time you fill up
. You do realize all the oil is being thrown around and all up the dipstick. Oil in in the system and passages and needs to drain down to the oil pan for at least couple hours before you check. I 100% guarantee you the oil will be all over the dipstick if you check when you are gassing since you have been driving it. Best to check on a 100% level surface and overnight. That is an accurate reading and everything else is 100% FALSE and waste of time. keep checking that oil every time you gas and don't bother with tire pressure while gassing.Thread
CFAUVEL
Oct 1, 2015 03:20 PM
