over drive button....
Old Nov 7, 2013 | 01:21 PM
lionofmalta's Avatar
lionofmalta
Default over drive button....
i just bought a 2008...350z....with a auto,,tranny..just notice...this model dosent have a overdrive button.....with the automatic tranny????
Old Nov 7, 2013 | 01:28 PM
KornerCarver's Avatar
KornerCarver
I believe 5th gear is an overdrive gear. Thinking here, I don't remember seeing an overdrive button in any car for years.
Old Nov 7, 2013 | 01:37 PM
pyshin's Avatar
pyshin
"Oh, the red button there kid, don't ever, ever touch the red button."
-Kay
Old Nov 7, 2013 | 03:01 PM
Jennifer 2's Avatar
Jennifer 2
Lots of trucks and SUVs have overdrive buttons, but it isn’t to engage overdrive, it’s to lock out overdrive (highest gear) for towing, carrying heavy loads etc.
Old Nov 7, 2013 | 03:36 PM
KornerCarver
Now that I think about it, my 1994 Dodge Minivan had an overdrive lockout button. My 1999 and 2009 don't have an overdrive lockout.
Old Nov 7, 2013 | 05:25 PM
calidrew909's Avatar
calidrew909
get a truck if you want overdrive
Old Nov 7, 2013 | 09:14 PM
winchman's Avatar
winchman
If you put the shifter in manual mode, the transmission won't go (or stay) in fifth gear. Will that work for you?
Congrats on the new acquisition. As the local dealer says, "You're gonna love the car."
Old Nov 8, 2013 | 01:19 AM
lionofmalta
Default what is the reason with the rude remarks
We are all here as z owners..learning about our z cars...No need for the rude remarks..this is totally not needed
Old Nov 8, 2013 | 02:42 AM
JCITY's Avatar
JCITY
Buy an electric supercharger.
You'll get better results.
Old Nov 8, 2013 | 05:57 AM
JERZ350's Avatar
JERZ350
Not every car has an overdrive option. Z isn't one of them
Old Nov 8, 2013 | 05:59 AM
Syner's Avatar
Syner
You're lucky I didn't see this earlier. You got off easy.
Old Nov 8, 2013 | 08:57 AM
stuartc323's Avatar
stuartc323
Da Fuq? You have been learning about your car for over 3 years now?
Syner's Avatar
Syner
I missed that.
Old Nov 8, 2013 | 08:59 AM
travlee's Avatar
travlee
Master
good times
Old Nov 8, 2013 | 06:01 PM
Spike100's Avatar
Spike100
350/370z’s do not have an overdrive button. Volvo’s and heavy trucks have an overdrive button.
Not flaming… just educating. And… I did not see any rude remarks.
--Spike
Old Nov 9, 2013 | 06:35 AM
Jah70's Avatar
Jah70
I didn't see any rude remarks but I think you should clench your butthole for the people that's about to flame you.
Old Nov 10, 2013 | 07:08 AM
l2iceman's Avatar
l2iceman
+1 to electric supercharger.
Old Nov 10, 2013 | 08:24 AM
Jennifer 2's Avatar
Jennifer 2
Lionofmalta, just because you don’t have a cute little button to command your transmission in and out of the top (overdrive) gear doesn’t mean you can’t have fun and amusement while driving an auto Z. Obviously (if you want a more peppy response on a steep grade) you can use the manual shift function to hold the car in 4th gear.
A more subtle amusement is persuading the torque converter to unlock. I live near a highway that climbs a long hill. Whenever I’m driving an auto equipped car up it I try to see what technique will work to unlock the converter. Usually I try being stingy on the throttle, holding it steady until just before the car starts to bog down an lose speed. At this point I delicately put a little more pressure on the gas pedal, (too much throttle on a steep hill will just cause the transmission to downshift), but just the right amount will kick the converter out of ‘lock’. (Some cars need a subtle double pump to convince the ECU that unlocking will smooth things out).
Once unlocked the ingenious components inside the converter are free to multiply torque providing a slightly lower gear ratio (usually about 200 more RPM) to haul the car up the hill. Both the manual and automatic Zs are an overdrive in their highest gear and a 1 to 1 ratio in the 2nd from the highest gear. However, the autos can produce a ratio halfway in between 4th and 5th when needed.
Try this, you might not feel the ‘unlock’, but you will see it on the tachometer. A few of those rpm are slippage, but like Goldilocks you might find this ratio (that’s not too hi and not too low) just right to crest the hill without wasting the gas needed for a complete downshift.
I don’t have an auto Z, so let me know if yours can lock and unlock at your beckoning.
Old Nov 11, 2013 | 02:15 AM
Firebase99's Avatar
Firebase99
--Spike
I have a 2013 Volvo S60 T5, theres no overdrive button.
Old Nov 11, 2013 | 03:03 AM
Spork's Avatar
Spork
Why...do...you.......insist..,,,.on.,.,.,doing.,.,this.,.,.b ullsh*t?
