almost let the lady go
Old Jan 22, 2014 | 09:22 PM
rivas_z33's Avatar
rivas_z33
Originally Posted by Syner
I got singled out
Old Jan 22, 2014 | 09:24 PM
The_Assassin's Avatar
The_Assassin
Good job keeping the Z. Wrx aint that fast anyway. My buddy has a 2004 wrx on 17 pounds of boost with some exhaust work done and I still walk in him my stock hr.
Old Jan 22, 2014 | 09:31 PM
rivas_z33's Avatar
rivas_z33
NICE
Old Jan 23, 2014 | 02:36 AM
oldschool350z's Avatar
oldschool350z
Originally Posted by RMichael
I rarely laugh at stuff but I chuckled at you understanding the huge maintenance bill.
Haha I'm glad I could make you laugh.
I have no idea why Subaru uses timing belts. You have to replace it normally at 60k and 105k. We have a timing chain, and will never incur those costs. I've seen many legacy gt and wrx owners miss timing and slip belts then need a rebuild.
Old Jan 23, 2014 | 06:14 AM
Syner's Avatar
Syner
Your friend can't drive.
Old Jan 23, 2014 | 08:22 AM
oldschool350z
It varies depending on the owner but turbo doesbt spool up until higher in the rpm band. They are slow until the turbo hits. Even from the factory they are running lean to pass state emissions.
Old Jan 23, 2014 | 08:30 AM
Syner's Avatar
Syner
17lbs though? I would think that would at least keep up with an HR.
How much do they run off the assembly line?
Old Jan 23, 2014 | 11:29 AM
Nismo350z#0310's Avatar
Nismo350z#0310
If anyone wants to know the joys of a WRX google Subaru WRX Ringland Issues.
It's a well-known and well documented issue with Subaru, especially if you've ever owned and/or modded one.
Old Jan 23, 2014 | 01:14 PM
oldschool350z
well I was looking into the newer generation but I think they run 12-14 stock boost from the factory.
In 2008-2009 they had huge issues with the engines where a brand new one with under 10k would need a engine replacement.
Old Jan 23, 2014 | 01:16 PM
oldschool350z
Exactly. It's just like the head gasket issue with the earlier 2.5l boxer engines. Subaru acknowledges the design issue and only have owners a "coolant conditioner" to put in.
I peter owned a 2000 2.5rs and parted it out because the engine went due to a blown head gasket.
Old Jan 23, 2014 | 01:48 PM
Nismo350z#0310
Not only was it a design failure but it's also, as someone said earlier, exponentiated due to the stock tune being so lean. People could literally drive it hard enough long enough in stock form and it would go boom. Compression would be crap, obvious loss of engine power would be symptomatic.
Aloharacing
Mar 21, 2003 10:49 AM
CoachZ
Nov 26, 2002 05:24 AM
fatZo
Cleaning & Detailing
Oct 31, 2002 12:40 PM
SHO-TIME
Oct 25, 2002 06:20 PM
RobJames
Oct 12, 2002 01:28 PM
