Bad diffrential or axles
Old May 5, 2015 | 03:29 PM
07_3fitty_z's Avatar
07_3fitty_z
Default Bad diffrential or axles
When ever i shift at a Little higher rpms,it feels like my rear tiers are gona come of. The car feels like it goes side way a little like one tire is spinning faster then the other , mostly between 2 nd third. i feel it pulling hard to the left but then it strignts its self is a slight pull. Is not wheel spin cuz is between 3 -3500 rpm Could this be the axles or diff Im getting a lot of clicking nd pooping from the rear passenger side tire. Thank you
Old May 5, 2015 | 03:47 PM
oldschool350z's Avatar
oldschool350z
Lol pooping.
To be honest hard to diagnose too many variables.
How many miles and when was the diff fluid changed last?
Old May 5, 2015 | 03:49 PM
07_3fitty_z
Originally Posted by oldschool350z
Lol pooping.
To be honest yes i was pooping lol.. O damnn no clue then ?
oldschool350z
My bad I edited my post. I would say it's differential. Could be something as simple as fluid need to be changed.
Old May 5, 2015 | 03:52 PM
07_3fitty_z
Well i changed the oil about 12k ago? But changing the oil again soon
Old May 5, 2015 | 05:52 PM
Frank_White's Avatar
Frank_White
the answer is whiteline diff bushing
Old May 5, 2015 | 05:56 PM
07_3fitty_z
Mine has been torn up ever since i got the car 2 years ago. You really think is that ?.. I took a look at the axles they look fine no leaks or anythibg
Old May 5, 2015 | 06:15 PM
buddhamonk's Avatar
buddhamonk
Check the axles and diff mounts instead of pooping from the rear
Old May 5, 2015 | 06:31 PM
Zmandriving's Avatar
Zmandriving
i say blown differential bushing. The one that goes to subframe. When mine blew you could tell the rearend was a lot looser and got pop thud type sound.
Old May 5, 2015 | 07:43 PM
venture210's Avatar
venture210
any chance there's a locker differential in it... that would do it lol
Frank_White
^ that was my guess also but OP says its been blown for as long as hes had the car
Old May 14, 2015 | 04:06 PM
rustyschopshop's Avatar
rustyschopshop
I used to feel the same thing until i did my differential bushings. I only notice the problem once in a while so hopefully it doesn't reappear. Launches feel much firmer now. I do slightly suspect some is from the subframe bushings as well but will not be doing those for a while.
Old May 20, 2015 | 06:29 AM
ZaaronZ's Avatar
ZaaronZ
Interesting, mine seems to do this as well.
I have a 2003 touring Auto, with 143k miles.
Justin100
Nov 25, 2021 06:26 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
derekinthez
South East
Sep 28, 2015 06:35 PM
