Interior removal help?
Old Sep 22, 2015 | 04:13 PM
zayis94's Avatar
zayis94
Default Interior removal help?
Can't seem to find a way to remove this interior part on the doors.
Old Sep 22, 2015 | 04:37 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Its part of the door panel. Pull the handle should be a little plastic piece under it remove that under that is a 10 mm bolt remove that gotta unhook the door handle wires. Remive all clips hole door panel should come off once the arm rests and stuff are removed. Ill find you a link..
Old Sep 22, 2015 | 04:44 PM
dboyzalter's Avatar
dboyzalter
Originally Posted by VO...
Next step we must remove the hidden screw behind the door lever....
https://my350z.com/forum/maintenance...dow-motor.html
Find it all here good luck.
Old Sep 22, 2015 | 04:45 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
^^^^ This.
The door handle assembly is removed from the back.
As dboyzalter said, remove the plastic panel behind latch and the bolt behind.
Pry up the control panel on the armrest to reveal the other bolts you need to remove, disconnect window controls, then pry around bottom of door to free up the panel and lift off.
Sadly, I can do this in under five minutes now....
Helpful hint: use plastic panel removers to avoid marring the interior which remarkably scratches very easy.
Old Sep 22, 2015 | 05:01 PM
travlee's Avatar
travlee
Master
jeebus
Old Sep 22, 2015 | 07:21 PM
dboyzalter's Avatar
dboyzalter
Its whole dumbass...
Told him for you travlee
Old Sep 22, 2015 | 07:38 PM
zayis94's Avatar
zayis94
Awesome it did the trick appreciate it bud!
Old Sep 23, 2015 | 03:15 AM
travlee's Avatar
travlee
Master
3vilbunny
Jul 18, 2017 05:10 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
