KW Clubsport from 350z fit 370z?
Old Mar 9, 2016 | 01:16 PM
2fasst's Avatar
2fasst
Default KW Clubsport from 350z fit 370z?
My friends..can someone tell me if the KW Clubsport coilovers from a 350Z would fit a 370z?
I removed my Clubsport after about 11,000 miles of street use when I sold the car. I may be picking up a 370z for track use and I figure the Clubsport would be an awesome setup.
Please let me know..
thanks..
Old Mar 9, 2016 | 01:23 PM
nizmo_0385's Avatar
nizmo_0385
thanks..
No. Not without some work up front only. Im in the same boat with Stance ss+ pro. I removed them from my 350z in favor of the nismo suspension. Ill be transferring them to my g37 ipl coupe. The rears fit and are the same spring rate. (True type).
However the 350z and G35 use a pitch fork type lower bracket up front and 370z G37 use an eylet type lower bracket. I called stance and they said top hats dampening and spring rates on my particular setup was the same accept for the lower bracket/ mounting point. So they will send my the new lower bracket to be able to mount the fronts on my G37. So out of the box no they wont fit. However with a small parts swap they will. Youll need to call kw and get whatever measurements they need to get you set.
Stance was very helpful to me. Hopefully KW is the same.
Old Mar 9, 2016 | 01:26 PM
2fasst's Avatar
2fasst
cool! thanks for the detailed help buddy.
I've been test driving the 370z..and I like it.
I'm also waiting for the 2017 GTR..to see if there are any changes..and decide
Old Mar 9, 2016 | 03:52 PM
nizmo_0385's Avatar
nizmo_0385
Anytime man.
smokinbuddha
Jun 22, 2016 06:21 PM
Nackers
Mar 12, 2016 03:45 PM
zfernn_
Mar 11, 2016 02:53 PM
bocbos
Mar 4, 2016 09:35 AM
