HOw long does Osiris Uprev take to ship?
Old Sep 13, 2016 | 08:40 AM
travlee's Avatar
travlee
Master
does that include the license?
check out Bailey's in fort worth, they did my buddies ls swap in his g
Old Sep 13, 2016 | 08:43 AM
ZedFed's Avatar
ZedFed
Not quite sure on the license but they advertise that price. I'll find it when I get back and post
Old Sep 13, 2016 | 08:46 AM
travlee's Avatar
travlee
Master
Dyno Tuning
We usually charge a flat rate anywhere from $500-$650. If we feel you have a very difficult vehicle, we can also tune it hourly at $275/hr (usually takes 2-3 hrs per car)
http://www.prtperformance.com/dyno-t...nd-testing.php
Old Sep 13, 2016 | 08:52 AM
ZedFed's Avatar
ZedFed
Oh so they are $275 for 3 pulls oh ok. I was super confused on the $650 pricing and so on. Yea $275 for 3 pulls looks good
Old Sep 13, 2016 | 10:40 AM
coletrickle74's Avatar
coletrickle74
Lol you said you hoped it shipped on Monday, which is the same day they would of received the order. Clearly it wouldn't ship out same day. I have nothing constructive to say, but good luck. You'll get it tomorrow or Thursday, be careful with the cable and plug. I only used mine a handful of times and I already have to hold it a certain way for it to work
Old Sep 14, 2016 | 06:13 AM
seymore4's Avatar
seymore4
Professional
Do you have the one with the micro USB plug? Those are pretty flimsy, they only had one batch of those before they switched to the mini usb they use now, which is much sturdier.
Old Sep 15, 2016 | 05:43 PM
ZedFed's Avatar
ZedFed
Received it, went to use it, not work.... Cable not found. Even after the update.. Cable not found. My other odbII scanner works but this is not detecting. Wonder if I need to install windows 7
Old Sep 15, 2016 | 05:48 PM
seymore4's Avatar
seymore4
Professional
A few tips, the cable will only work with ONE of the uprev programs open at a time, so if you have more than one open close them all, unplug the cable, and plug it back in. Also disable any anti virus software you may have running. The security keys can be a bit finicky, so you may have to unplug it/ plug it back in a few times to get it to work.
Old Sep 15, 2016 | 06:54 PM
ZedFed's Avatar
ZedFed
Thanks man! Iwill try that BUT I had only UpRe Flasher on the cable management ane it still does not work thus imma go outside again right now and play with it. bare with me
Old Sep 15, 2016 | 06:56 PM
ZedFed's Avatar
ZedFed
Ahh the heck with it... imma install windows 7. This the test top anyways....
Old Sep 15, 2016 | 07:11 PM
seymore4's Avatar
seymore4
Professional
Unplug it and plug it back in a couple times. Usually works for me.
Old Sep 15, 2016 | 07:17 PM
ZedFed's Avatar
ZedFed
naa didn't work for me... did that like 8 times. I even held the top to make sure it plugged in all the way. Im already installing windows 7. I read some compatibility forums from another site, w7 seems to work the best as there is no support for 8.1 and 10... 10 sucks anyways
Old Sep 15, 2016 | 07:25 PM
seymore4's Avatar
seymore4
Professional
Maybe you got a bad one. I personally use windows 7 on a daily basis but have used it on both windows 8, and 10 machines with no problem.
Old Sep 15, 2016 | 07:29 PM
ZedFed's Avatar
ZedFed
Well im lost after this point if it doesen't work then. Guess its time to prep and call then
Old Sep 15, 2016 | 07:52 PM
seymore4's Avatar
seymore4
Professional
Hope it all works out for ya
Old Sep 15, 2016 | 08:31 PM
ZedFed's Avatar
ZedFed
Yep, bad cable unless there's a fuse or something for that
Old Sep 15, 2016 | 09:19 PM
ZedFed's Avatar
ZedFed
You want to know what trips me out? I just installed 7 and then of course the software bundle... Went right on through along with the drivers for the cable. Now when I order another battery for this damn laptop that only gives me 10 minutes of play, i will go back out and try again...
I did read some some on these cars that a white push pin or something in the kick panel... But I am filling any empty "non-used" fuse spot to make sure that the ODBII plug has power
openupitsdave
Dec 4, 2016 04:45 PM
mazzotta.al
Sep 7, 2016 05:32 PM
Extreme Dimensions
Southern California
Aug 29, 2016 03:03 PM
stendori
Aug 14, 2016 01:44 PM
