P0335 -Crankshaft Sensor Cause?
Old Oct 10, 2016 | 04:06 AM
BurgerBob's Avatar
BurgerBob
Default P0335 -Crankshaft Sensor Cause?
Hey All,
My z threw a P0335 code this morning. I know what the code is and have encountered this before.
The reason for the post is to ask you Z junkies- Why?
I know this is a common issue with the 350, but what causes this sensor to go bad? The first sensor I had go bad a year or so ago looked like it had a bite taken out of it.. what happens the the pieces of the sensor in the bell housing?
Anyway, just curious if any of you have found the cause of our trans eating the sensor. It has been bothering me since my first sensor went bad and will be bothering me while i replace this one!
Thanks,
BB
Old Oct 10, 2016 | 04:09 AM
travlee's Avatar
travlee
Master
did you replace it with oem or aftermarket?
Old Oct 10, 2016 | 04:41 AM
BurgerBob's Avatar
BurgerBob
OEM from courtesy parts
Old Oct 10, 2016 | 04:45 AM
travlee's Avatar
travlee
Master
that is weird, i know that some aftermarket ones can be a little longer... hence why i asked
Old Oct 10, 2016 | 04:52 AM
BurgerBob's Avatar
BurgerBob
I do have an aftermarket Clutch/Fly. Southbend "stage 2"
see post:https://my350z.com/forum/2003-2009-n...-flywheel.html
I was worried my kit may have come with a problem flywheel, but I did not order withing those years. Do these sensors usually just malfunction, or break within the bell housing? I am looking forward to getting the sensor out this time to see if it is broken or just dirty/malfunctioning.
Old Oct 10, 2016 | 09:16 AM
dkmura's Avatar
dkmura
General & DIY Moderator
There's no easy answer to why a sensor wheel breaks. It could be a bit of debris gets caught in there, or a material flaw in the part itself. No way to tell for sure, although I'm sure there are some factory engineers out there who have a more educated guess than this...
Old Oct 10, 2016 | 09:56 AM
BurgerBob's Avatar
BurgerBob
that is what i was thinking as well... so many possible variables. Ill also try and inspect my flywheel using the method in that post i linked just to make sure no bolts are loose and causing damage. Just curious about other Z owners and if they found anything as I have heard this is a common issue. I just like to avoid replacing parts without knowing what caused it to fail. Ill just chalk this one up to a hungry Z eating another sensor and replace it.
Old Oct 13, 2016 | 06:35 AM
BurgerBob's Avatar
BurgerBob
Interestingly enough, I performed an ECU reset that night and the car is running fine now. I am going to inspect the sensor this weekend to see for myself.
Old Oct 14, 2016 | 09:25 AM
samsniss350z's Avatar
samsniss350z
Let us know how you get on Bob as I for one would like to know how this pans out.
rcghalohell
Oct 11, 2016 01:38 PM
Z33benjamin
Oct 9, 2016 11:56 AM
oats456
Oct 8, 2016 07:23 AM
FJJeremy
Oct 4, 2016 09:03 PM
