Bolts on before tuning
Old Jun 1, 2017 | 09:18 AM
Osteven95's Avatar
Osteven95
Default Bolts on before tuning
Hey guys I had a question I have a 03 350z manuel I wanna add bolts on before tuning it to have a great effect what's the exact mods that I should add
Old Jun 1, 2017 | 10:40 AM
Atreyu'z 350's Avatar
Atreyu'z 350
https://my350z.com/forum/new-owners/...to-your-z.html
https://my350z.com/forum/2003-2009-n...questions.html
Old Jun 1, 2017 | 12:20 PM
dcains's Avatar
dcains
Not going to happen, but have fun trying. Bolt-on's on our cars, and especially a high-mileage 14-year old Z, will yield almost no performance advantages, but you might like the sounds of the intake and exhaust better.
Useful mods, are adjustable sway bars, lightweight wheels, better tires, driving school, Nismo stickers, etc. And old Z will most-likely have worn shocks, and I'd add those very close to the front of the list. Don't buy stupid purple Chinese-made coilovers just to impress the Honda kids. Do your research here on the forums.
Old Jun 1, 2017 | 03:29 PM
rearranged's Avatar
rearranged
Bolt on a supercharger or turbo kit. That will have great effect.
Old Jun 2, 2017 | 12:34 PM
iideadeyeii's Avatar
iideadeyeii
Bolt the nitrous right next to the supercharger and turbo
Old Jun 3, 2017 | 11:15 AM
slicnicz33's Avatar
slicnicz33
5/16 motordyne plenum spacer w/copper gasket
Longtube exhaust headers or something other than oem
13 lb flywheel
TB spacer
High flow cats
Convert to e85
Change diff setup to a 3.7 or 3.9
Port and polish inside intake manifold and plenum
370z y pipe
Nitrous
Track time
Sway bars
Gutt interior
F/I
Search button works wonders, probably best to look in the N/A build section
Old Jun 3, 2017 | 12:52 PM
rearranged's Avatar
rearranged
13 lb flywheel
TB spacer
High flow cats
Convert to e85
370z y pipe
Nitrous
Track time
Sway bars
Gutt interior
F/I
Longtube headers and high flow cats? Good luck getting both on.
Old Jun 3, 2017 | 01:06 PM
slicnicz33's Avatar
slicnicz33
I just put a list of options for possible bolt ons he could do. Obviously you cant put longtube headers paired with cats at all , he really needs to spend about 3 days of doing research on my350z to decide, but in all reality the $/hp ratio isn't really worth it on the N/A level
Old Jun 5, 2017 | 02:26 PM
rearranged's Avatar
rearranged
Depends on your goals. I spent $2500ish on pop charger, plenum spacer, hfc's, dual exhaust and uprev tune. Dynoed at 249hp. Hp wasn't my goal though. I wanted it to sound better. I accomplished that.
Old Jun 6, 2017 | 04:50 AM
travlee's Avatar
travlee
Master
this will prob kill op's hopes and dreams....
but i was some boat with my HR... intake, art pipes, tdx2, and tune cost $3200 ish for 17whp
Old Jun 6, 2017 | 06:05 AM
iideadeyeii
Andddd that's why you have a vette now
Old Jun 6, 2017 | 06:08 AM
iideadeyeii
Can't beat a cheap/custom turbo. I'm in about $1900 in on mine and got +60whp and +112 tq at the wheels
Old Jun 6, 2017 | 06:13 AM
travlee's Avatar
travlee
Master
isnt much better on the vette... intake, heads, long tube headers, axle back and tune got me 50 whp at the cost of $7400 ish. although about half of that was labor. i will get the big bump in power when i cam it, but that wont be until it is retired to a weekender
Old Jun 6, 2017 | 06:15 AM
iideadeyeii
$148 vs 188 per horsepower, but that seems like a lot for those parts. They really did kill you on labor. . .literally what I paid for my z 5-6 years ago : P
Old Jun 6, 2017 | 06:24 AM
travlee's Avatar
travlee
Master
let me get actual part break down, they didnt install the axle back though. so about 17-1800 in labor i would guess
intake $150
heads $1900
headers and xpipe $1700
Axle back $1725
Tune $500
Old Jun 6, 2017 | 06:28 AM
iideadeyeii
I'm just surprised you didn't do the cams when the heads were done? The labor is the same, you just needed the parts?
Old Jun 6, 2017 | 06:35 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
^^^ Key point.
People, let's keep things in perspective here... 15 WHEEL horsepower IS a "feelable" difference and it can change how the car behaves in corners and on straightaways.
But no, mo'power - no matter how much or how little gained is always a GOOD thing. The factor that deadeye and Trav point out very correctly is the all important "dollars/WHP" ratio one is willing to pay. And Z's have a pretty high $/HP ratio... but worth it.
I still tell anyone who would listen that besides driving school, that old hot rodder's trick of lowering the rear gears is truly one of the best ways to give one that extra punch without touching the engine at all. Especially in an HR car. (Of course, you have to be able to live with the downsides as well...)
travlee's Avatar
travlee
Master
i had a self imposed budget of $5500, def wanted to do the heads because of the valve issues, so i could have done either the headers or the cam... i chose to do headers because i didnt want to have a choke point. i know i did it backwards from most, but even the mechanic said with my choices he would have done the headers also.
whenever i do the cam it will only be $1900 installed with a retune which will put me around 565-610whp depending on the cam i go with
Old Jun 6, 2017 | 10:16 AM
iideadeyeii
Screw the idle, go for the 610whp one!
I've been in the passenger seat of a GT500 with 565whp/tq at 2300rpm... The thing was a MONSTER. Felt like I was on my gsxr-750 AND he spun the tires up to 80 before letting off..still pulled HARD even without traction.
Only other time I've "felt" like I was in a Monster fast car was a 1970 Chevelle SS 396 with around 400hp, but it was only a 15 second car...the super low gearing he had in it made you think it was faster than it actually was.
Old Jun 6, 2017 | 10:23 AM
travlee's Avatar
travlee
Master
they say it surges pretty bad in the lower rpms... here is the cam i might go with one day
