05 350z high mileage offer quote
Old Sep 3, 2017 | 07:14 AM
Toneloc's Avatar
Toneloc
Default 05 350z high mileage offer quote
05 350z 6mt, pikes peak white, 180,000miles base model clean and tastefully modified. I have owned this vehicle for almost 6 years daily driven I have owned it since 90000miles. Looking for an honest estimate offer I could sell my vehicle for. I know what kbb says. Mods and pics listed below. Almost 6grand in parts and labor etc. I listed all what I bought off of z1 and conceptz.
Both wheel bearings went out at 150,000miles and cost $600 a side to replace other then that bone solid reliable. I wanted to have a clean looking 350z with performance as the main goal. Here are most of the mods below with prices. And yes I did post double of whiteline bushings due to me moving to sc and losing the first set. They are for sale fyi.
Injected Performance Rear Differential Brace Standard 03-08 350Z Z33 $199.00
Paint - Touch Up Ivory Pearl QX1 $9.95
Nissan OEM 350Z Differential Rear Mounting Stud Z33 $2.96
Red Line MT-85 Manual Transmission Fluid 75W85 GL-4 4-Pack $51.80
Nissan OEM 350Z Center Console Shifter Boot Finisher Z33 04-05 $120.58
Project Mu Akebono Caliper TYPE NS400 Rear Brake Pads 09+ Nissan 370Z / 08+ Infiniti G37 $95.00
ZSP Wilwood Clutch Master Cylinder Upgrade 03-06 350Z, 03-06 G35 Sedan, 03-07 G35 Coupe $199.00
JWT Clutch / Flywheel Combo VQ35DE Package 04-06 350Z Z33, 04-06 G35 Sedan $745.00
2 Bolt Exhaust Gasket $14.00
Whiteline 350Z/G35 Front Lower Shock Absorber Bushing $49.95
Whiteline 350Z/G35 Front Lower Control Arm Inner Bushing $53.95
Whiteline Differential Bushing Kit (350Z / 370Z / G35 / G37) $98.00
OEM Transmission/ Diff Drain Plug Sealing Washer $10.40
Z1 Motorsports Magnetic Oil Drain Plug Copper Crush Washer $1.50
Red Line 75W90 Diff Fluid (1qt) $25.90
Red Line MT-85 $51.80
Z Speed Performance Aluminum Undershroud- Finish: Brushed Aluminum $189.00
Z1 Upgraded 350Z Hatch Struts - Strut Option: HP $68.00
Magnetic Oil Drain Plug $9.98
JWT Short Pop Charger Filter ONLY $65.00
JWT 350Z Pop Charger Intake $110.00
Z1 VQ35DE Plenum Spacer $148.00
Z1 350Z / G35 Brake Upgrade Package (Non Brembo)
- Select: 350Z
- Brake Fluid Options: ATE Super Blue
- Rotor Type: Drilled & Slotted
- Year: 2005
- Brake Pad: Hawk HP Plus (03-05 Only) $598.00
Z1 350Z/G35 High Flow Metallic Catalytic Converters (DE Models) $378.00
Miscellaneous
Full exterior/engine bay detail 500$
Uprev liscense 300$
Uprev dyno tuned 300$
Clutch/flywheel/master slave install 600$
Used stainless steel injen catback 300$
Magnaflow x pipe 100$
Exhaust labor 100$
Window tinted 100$
Stainless steel clutch and brake lines 200$
aftermarket trans mount (stiffen up drivetrain flex and stiffen shifts) 200$
grand total little over 6grand. dynoed 255hp and 245trq 15% correction.
What would you honestly offer for my z?
Old Sep 3, 2017 | 11:50 AM
liven Z life's Avatar
liven Z life
7500$ tops because of millage
Old Sep 3, 2017 | 01:28 PM
bealljk's Avatar
bealljk
whatever KBB has it listed for your area...
You have quality parts on the car but they arent going to increase the value above KBB. Back out all the 'parts & labor' costs - you never get money out of aftermarket parts.
sell the car to someone over the age of 35 who will appreciate the condition of the car, appreciate the subtleness of the aforementioned upgrades, and will use this car as a weekend whip and not a daily driver.
Beautiful car, looks like you took great care of it -
Old Sep 3, 2017 | 01:32 PM
oldschool350z's Avatar
oldschool350z
You paid $1200 to replace your whee bearings???
Are you stupid that should cost $200 max.
Old Sep 3, 2017 | 01:42 PM
CK_32's Avatar
CK_32
$3,500 cash.
Old Sep 3, 2017 | 01:44 PM
Toneloc's Avatar
Toneloc
Originally Posted by CK_32
$3,500 cash.
Any info in backing up that response? Because even a stock one at this mileage has gone a little higher then this. But I do see your in California so maybe so.
I live is Greenville south carolina
Old Sep 3, 2017 | 02:05 PM
Toneloc's Avatar
Toneloc
So 4892$ per kbb. tack on 25% in parts. Lets say 6grand a fair price?
I just don't wanna drop 3-4grand in a used motor/ transmission and consuming all my home time in the garage wrenching on something I will never get a return investment on other than the satisfaction of saying I swapped it.
Id rather invest in a sportbike again and I will always get a return investment there.
Old Sep 3, 2017 | 02:10 PM
bealljk's Avatar
bealljk
Ask $6 for sure but you'll get talked down to $5 and sell it for $5200
very very very few things with motors are investments...
Old Sep 3, 2017 | 02:55 PM
oldschool350z
KBB. But it's only worth what someone is willing to pay.
You can find a z with 120k for $7000 or less especially in California.
