350z crankshaft pulley dampener bolt
Old Oct 10, 2017 | 03:48 PM
P1freddy's Avatar
P1freddy
Default 350z crankshaft pulley dampener bolt
Hey guys I recently heard some chain slap noise coming from the front cover I removed the front end of the car looked at my main tensioner and guide seemed perfectly fine, have everything ready to remove the front cover but my crankshaft pulley bolt won't budge, I used a 1/2 inch impact, I used the breaker bar and starter method won't budge please help. 06 manual 350z
Old Oct 10, 2017 | 04:09 PM
Atreyu'z 350's Avatar
Atreyu'z 350
https://techmate.service-solutions.c...ti&SKU=J-44716
You're going to need this exact tool to hold your flywheel in place. Then get yourself a 39in by 3/4in breaker bar with a 3/4in 19mm deep socket. It'll come right off.. Trust me.
Old Oct 11, 2017 | 06:01 AM
iideadeyeii's Avatar
iideadeyeii
There is already a post about this with my confirmed $6-$10 solution. Find it
Old Oct 11, 2017 | 07:05 AM
Atreyu'z 350
The rope method?.. I never felt too comfortable trying that. Didn't want to damage anything internally if the crank bolt was seized... But hey, maybe I'm worrying too much.
Old Oct 11, 2017 | 09:34 AM
iideadeyeii
Noo
iideadeyeii
Noo, but that works
Old Oct 11, 2017 | 09:40 AM
Atreyu'z 350
Uhhhh.. That dirtbike piston stopper tool thing?
Old Oct 11, 2017 | 01:42 PM
P1freddy's Avatar
P1freddy
I'm not trying to spend 150$ on a metal tool to hold a flywheel
Old Oct 11, 2017 | 01:43 PM
P1freddy's Avatar
P1freddy
can you please explain the method
Old Oct 11, 2017 | 02:04 PM
Atreyu'z 350
Put your transmission in 6th gear and have someone apply the brakes, then try.
Last edited by Atreyu'z 350; Oct 11, 2017 at 02:06 PM. Reason: Because I'm anal as hell
Old Oct 11, 2017 | 03:45 PM
Atreyu'z 350
Then go look through his 2,260 post to find the $10 mystery answer.
Old Oct 11, 2017 | 03:50 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Ill tell you how I did it... 6th gear. Ebrake... Cut off belt... Strapped belt and tightly ratcheted down flywheel... Big *** breaker bar... Jack handle... Boom and boom.
Old Oct 11, 2017 | 03:58 PM
Atreyu'z 350
^ The $25 way..
Old Oct 11, 2017 | 08:31 PM
terrasmak's Avatar
Breaker bar on the floor and tap the starter, it works well.
Thank me later
Old Oct 12, 2017 | 05:56 AM
iideadeyeii
http://www.ebay.com/itm/PISTON-STOP-...tqik-w&vxp=mtr
This one doesn't have the plastic at the end like I had, but the plastic broke off anyways and I had to use a blow gun to get the piece out.
OR get a stronger impact. I use a 1200ft/lb now (3/4). Paid $120 for it and it's beautiful
Old Oct 12, 2017 | 06:07 AM
Atreyu'z 350
I'm curious which way he's gonna choose now...
