Starting issue
Old Feb 24, 2018 | 03:16 PM
Gr8tobet8's Avatar
Gr8tobet8
Default Starting issue
I have A 2008 z...broke down on me on Monday....when i started it, it had a rough idle...had bad misfires and finally wouldn’t start...ran the codes and it had two 02 sensor codes and a misfire code...pulled the plugs and the plugs were fouled....the car runs rich after installing test pipes....i replaced the plugs and tried to start it...it cranks but doesn’t turn over...when you spray starting fluid into the intake it’ll turn over but runs really rough....it has a new fuel filter...new plugs...new intake filters...new coil packs....I’ve cleaned the MAFS.....any ideas on what to possibly check next would be great...the mounts for the test pipes are a few inches long where the 02 sensors mount which has made it run really rich...should i swap those test pipes and install new sensors?
Old Feb 25, 2018 | 10:20 AM
liven Z life's Avatar
liven Z life
Sensors are reading bad because of the test pipes obviously... as far as the other stuff is concerned that I don’t know... might need a tune what other mods do you have?
Old Feb 25, 2018 | 01:39 PM
Gr8tobet8's Avatar
Gr8tobet8
none...
Old Feb 25, 2018 | 04:21 PM
Atreyu'z 350's Avatar
Atreyu'z 350
Did it throw the code for the misfire before or after you got new coil packs? And who are these coil packs manufactured by?...
Old Feb 25, 2018 | 06:23 PM
Gr8tobet8's Avatar
Gr8tobet8
OEM from Nissan....it threw the code when it lost power and wouldn’t start
Old Feb 26, 2018 | 04:14 AM
Atreyu'z 350
...Did it throw the misfire code before or after you installed the new OEM Nissan coil packs?
Old Feb 26, 2018 | 04:24 AM
Gr8tobet8's Avatar
Gr8tobet8
both...this happened once before about 2 months ago...did a few things to it and it ran great...got in it to go home from work and it completely died...replaced the plugs and it just cranks...**** some starting fluid in it and it would turn over but runs horribly
heyitzalex
Dec 4, 2022 12:50 PM
tougeracing
Jan 11, 2011 01:07 PM
Chef-J
Mar 25, 2008 05:08 PM
Ruthless18x
Oct 2, 2007 10:08 PM
