Difficulty starting...but ended up starting. why?
Old May 9, 2009 | 06:42 PM
heyitzalex's Avatar
heyitzalex
Default Difficulty starting...but ended up starting. why?
I had a quick scare today, when my car wouldn't turn over after around 15 cranks. So I tried again and it turned over on the 10th crank or so. It was the first time this happened, usually it turns over on the 4th or 5th crank easily. Maybe crank angle sensor? Cranks are quick, battery was replaced about a month ago. GTM stg1 longblock, GTM 272 turbo cams, GTM fuel return system, jwt 530bb, fcon vpro.
Old May 9, 2009 | 09:34 PM
ADMAN's Avatar
ADMAN
That's usually the symps of the crank sensor. But, with your other mods it's hard to say.
Old May 9, 2009 | 11:57 PM
jining's Avatar
jining
Was it sitting for a long time?
Old May 11, 2009 | 08:41 AM
heyitzalex's Avatar
heyitzalex
it was parked for about 3 hrs
Old May 11, 2009 | 12:54 PM
sentry65's Avatar
sentry65
the burninator
this might be really stupid, but how old is your battery?
Old May 11, 2009 | 01:28 PM
heyitzalex's Avatar
heyitzalex
battery was replaced a month ago
Old May 11, 2009 | 02:00 PM
Fairlady_z33's Avatar
Fairlady_z33
how about the weather and what step plugs do you have. Also with higher duration cams it usually takes longer to crank. Maybe just all the right factors where in play at that momment. But it wouldnt hurt to check the crank angle sensor.
Old May 11, 2009 | 03:39 PM
heyitzalex's Avatar
heyitzalex
plugs are one step colder and it was sitting out in the direct sun for a few hrs. thats what i figured at the time (all the right factors where in play at the moment) but i'll check out the crank angle sensor.
Old May 11, 2009 | 04:13 PM
westpak's Avatar
westpak
SFZCC
+1
Old Dec 4, 2022 | 11:50 AM
CCCLZ-Silver's Avatar
CCCLZ-Silver
Yes, it has been sitting since March. O got it home and it sat for a couple of months before I even thought about it.
Old Dec 4, 2022 | 12:50 PM
travlee's Avatar
travlee
Master
13 year dead thread. Post was probably created when you were in diapers
logan w
Mar 14, 2022 05:46 PM
Shawn Hancock
May 5, 2015 02:02 PM
konrad
Mar 12, 2011 04:58 PM
team1320350z
Jul 13, 2008 02:09 PM
ssc
Apr 7, 2007 04:55 PM
