strut tower brace
Old Jan 10, 2019 | 04:52 AM
winger075's Avatar
winger075
Default strut tower brace
Question: when removing strut tower brace does my Z need to be lifted or not? same goes to re-installing
Old Jan 10, 2019 | 09:30 AM
icer5160's Avatar
icer5160
No, your Z doesn't need to be jacked up or lifted off the ground for strut tower bar removal. You can do this while on the ground. You just need to loosen the jam nuts on the OEM brace in order to rotate the tension rod. I recommend marking the tension rod position with the nuts before loosening anything, so you can put it back exactly as it was. Failure to do this can result in damaging the threads on the two tower studs or the six bolts that hold the brace in place.
-Icer
Oct 23, 2005 01:30 PM
protocav
Jun 8, 2005 10:53 AM
Tim'sZ
Aug 22, 2004 11:55 PM
2FST4U
May 12, 2004 06:42 PM
raceboy
Jun 27, 2002 05:50 PM
