How to fill the 6MT back up?
Old Feb 22, 2004 | 10:13 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Default How to fill the 6MT back up?
I have a long hose with a funnel, but it was about 1 ft short to make it to the fill hole from the front. Anyone have ideas on how to refill the tranny back up once drained? Luckly I didn't drain it yet!
Old Feb 22, 2004 | 10:55 AM
wren57's Avatar
wren57
Get another funnel, and dual-funnel that biatch.
Old Feb 22, 2004 | 10:57 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Hmmmmmmmmmmmmm.....its drained now, because i might have figured out another way, I hope it works.
Old Feb 22, 2004 | 01:12 PM
seanazzy's Avatar
seanazzy
let me know how it works out/whatever method you use
Old Feb 22, 2004 | 04:05 PM
rufus3000's Avatar
rufus3000
Default Re: How to fill the 6MT back up?
What you want to do is get about 3' of clear 1/2" plastic tubing "they sell it a pet stores for aquariums. Press fit the end of your funnel into one end of the tubing. With it being clear you can tell when the tranny is topped off with out wasting alot of fluid.
Plug or cap the tubing to keep it clean for the next time you need it.
Old Feb 22, 2004 | 04:24 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Default Re: Re: How to fill the 6MT back up?
Okay guys, finished. I bought 2 things. A hose that attaches itself to the bottle, and a small pump from autozone. The 1st one didn't work, but the small pump did. It is a hand pump and it worked beautifully, but a bit messy.
My shifts are much easier now, 2nd gear still has me wonder why I have that little metal sounding noise when I go into it, but other than that its all set.
Amsoil 75w90 Gear oil, 2000 series. .. Love it!
Old Feb 22, 2004 | 07:16 PM
vonsudderth's Avatar
vonsudderth
Check the Technical Service Bulletin on the teansmission and you will see that you have to use GL4 75W85 weight gear oil. This is required for your transmission warranty. But, most dealers do not stock it and you will have a hard time finding this specific weight gear oil. Just thought that I would warn you. If your transmission has to have warranty work done on it and the dealer or zone rep finds that you have changed to the wrong weight oil they might not warranty the transmission. If you want the TSB for this send me an email.
Old Feb 23, 2004 | 09:05 AM
Z'd's Avatar
Z'd
Amsoil Series 2000 75W90 meets the GL-4 API service code requirement.
Old Feb 24, 2004 | 05:07 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
That isn't true. 75w90 meets and exceeds the specifications. Also my 1-2 shift is now perfectly SMOOTH, no more grinding after 100 miles of driving! Amsoil is great!
Old Feb 25, 2004 | 04:45 AM
VQ35DES's Avatar
VQ35DES
Whats the change intervals? Should you do one after the break-in??? (esp if your a amature driver)
Old Feb 25, 2004 | 03:15 PM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
I would say every 30k, but the first one should be changed as soon as possible.
sales@czp
Sep 23, 2019 03:30 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Stevo Z
Oct 3, 2015 09:14 PM
Depravity
Oct 1, 2015 04:49 PM
