How to remove a broken Pivot ball
Old Mar 8, 2019 | 10:15 AM
fiddy_sent's Avatar
fiddy_sent
Default How to remove a broken Pivot ball
Hey Guys,
Found a broken pivot ball when working on the project Z. This is how I fixed it!
Old Mar 8, 2019 | 10:48 AM
jhc's Avatar
jhc
General & Tech Moderator
Nice video!
Old Mar 8, 2019 | 12:21 PM
icer5160's Avatar
icer5160
Good stuff, is that an 03 transmission? I remember the pivot ***** on those were longer which put extra shear load (through the clutch & fork) on them resulting in breakage at the threads. Stronger aftermarket versions are available along with the upgraded cast clutch fork. The stamped steel clutch fork is weak and prone to flexing. I could be wrong, but I believe if you upgrade the clutch fork to the beefier cast unit, you can also upgrade to the stubbier/shorter pivot ball for the added strength.
Also, great job cleaning up that engine bay! Looking good man!
-Icer
Old Mar 8, 2019 | 01:03 PM
GEveryday's Avatar
GEveryday
^^ You got it all right
Old Mar 16, 2019 | 12:17 PM
fiddy_sent's Avatar
fiddy_sent
-Icer
Thanks man! yeah it's an 03 and Yeah that is all correct for sure and I am going to do that eventually but i am actually planning a 1jz swap so I'm saving the upgrade for that stuff until then.
BonesZ33
Nov 28, 2012 07:56 PM
multiscape
Feb 10, 2008 09:22 PM
kwiker
Jan 31, 2007 06:40 PM
