Car will not start
Old Mar 9, 2019 | 07:09 PM
Ccvu1113's Avatar
Ccvu1113
Default Car will not start
BACKSTORY : Bought it from some guy, 2004 350z, worked great but the amp wasn’t working so I disconnected it and it kept not starting at random times and I would have to take the audio fuse out for it to start and a month later I found out it was because there wasn’t a secure connection. It works for like a week then it went back to the same problem so I bought two new battery terminal connectors and it worked for a little bit again... but now it’s not working
THE PROBLEM: When I drive it, with the audio chip in it works fine ... but randomly sometimes when I stop and turn it off, it doesn’t start and makes a “chut..... chut.... chut...” autozone diagnosed it and battery is 100%, alternator is working, and starter is working... I have no idea what is causing this.
Old Mar 9, 2019 | 07:55 PM
jhc's Avatar
jhc
General & Tech Moderator
Normally if the battery load-test and key are good the starter/solenoid would be suspect. Can you roll-start it?
tclark90
Nov 7, 2016 06:55 PM
Keeslerj
Nov 24, 2013 11:38 PM
Sequence
May 18, 2013 07:01 PM
iamahobo
Jul 13, 2011 05:41 PM
zand02max
Nov 5, 2005 04:16 PM
