Differential Removal and Replacement
Can the differential (pumpkin) be removed and replaced using a hydraulic floor jack while the car is on jack stands? I'm considering doing a LSD install (Quaife)
on my base 07. I believe the thing weighs about 90 pounds. I've seen instructions on this site on how to do the installation. If I run into
trouble, I plan to haul the differential and LSD parts to a pro to do the rebuild (and save some money).
Actually you can do about anything with the correct jack stands. It often is not as easy as doing things on a lift, but it is possible. Be cautious and make sure there is safety "catch."
Pumpkin removed
It is difficult to balance it on a jack if yours is missing the jack plate like mine was. The pumpkin weighs about ~80 lbs without fluid. You can man handle it in place. The most difficult part was clearing the sway bar. Though I wouldn't recommend it.
carboyanno
Jun 14, 2016 05:46 AM
ebadai98
Drivetrain
Nov 11, 2012 10:16 AM
