Built sound system, now gauge cluster doesn’t work (Fuel, RMP, Speed, ABS)
Old Jun 1, 2019 | 07:39 PM
TannerGreenwood's Avatar
TannerGreenwood
Default Built sound system, now gauge cluster doesn’t work (Fuel, RMP, Speed, ABS)
Sorry I’m not to this site and don’t exactly know how to use it but i’ve been working on a brand new sound system for my car and it’s been quite the task because the previous owner made such a mess of the wiring system and I just finished getting everything working and sounding good but when I put the car back together my ABS light is now stuck on and it was never on prior to starting along with the fuel light. I’m wondering is anyone knows which wires connected to the gauge cluster control those lights because I think I may have damaged one in the process of setting everything up my 350z is a Base model 2003. The fuel light might honestly be on because the car could be out of gas but I’m not sure. One things I do know is they had a navigation system installed into the cubby screen and I didn’t want that so I took it out it was grounded to a purple wire near the e-brake and a removed it’s wire from the purple wire and then after noticing the abs/fuel light were on after putting it all back together thought maybe that could be the problem so re attached it but with no success if anyone knows anything this issue please help! Thank you so much
Edit: none of my gauges work (Fuel, ABS, RPM’s, Speed, E-brake light) not sure what I cut or miss places
Old Jun 1, 2019 | 09:20 PM
mr. sparco's Avatar
mr. sparco
Check all your fuses.
Old Jun 2, 2019 | 09:39 AM
TannerGreenwood
So I checked the fuses and it wasn’t that but I found in another forum that it could be the AC box wires and after doing that it work! Except now it throwing a Service Engine light anyone know what it could be?
Old Jun 2, 2019 | 06:52 PM
khnitz's Avatar
khnitz
5 Year Member
You'll need to use an ODB2 reader to get the diagnostic codes and go from there. If you haven't already, download the factory service manual (FSM) to aid in your repair/diagnosis, as well.
Old Jun 2, 2019 | 09:26 PM
i8acobra's Avatar
i8acobra
Was just going to tell you it's the A/C and meter amp. But, you already got it.
pchio
Apr 21, 2017 07:38 AM
DieselandZ
Mar 31, 2015 06:35 PM
Daytondakid13
Aug 26, 2014 08:57 AM
ccchaorule
Aug 16, 2012 12:12 PM
hershell
May 20, 2008 08:50 PM
