Sponsored by:
Sponsored by:
Car won’t start U1000 code
Old 06-15-2019, 12:12 PM
Tristan_BlueZ
Tristan_BlueZ's Avatar
Default Car won’t start U1000 code
So I was trying to test my coil packs and while trying to reach the one under my air intake I slipped with pliers and cut into one of the wires causing a spark and the engine shut off and won’t start. All my fuses are good and the car will crank just not start. When I put the key in the on position all the lights come on but my radiator fan kicks on full blast. The only code I’m running is U1000 and I can’t figure out what’s keeping it from turning over
Old 06-15-2019, 01:07 PM
travlee
Master
travlee's Avatar
Received 9,059 Likes on 6,523 Posts
Try resetting the ecu
Tristan_BlueZ (06-15-2019)
Old 06-15-2019, 05:29 PM
albaugh81
albaugh81's Avatar
U1000 is a scary code to have, i've seen this code twice on my car in 2018 where my car would just shut off at highway exits. It's a communication error code with the CAN bus. I bought a new ground wire for the battery & it never happened again. The new ground cable for the battery was a better connection than the old cable. Buy one from conceptzperformance if you need one. We have more fuses behind the battery it's covered.
sleeper400
11-07-2021 01:03 AM
av8shunmeckanec
05-25-2018 01:31 PM
LeftLaneLuc
11-09-2016 10:38 AM
350licious
05-01-2012 01:58 PM
gregom
07-29-2008 12:17 AM
Quick Reply: Car won’t start U1000 code
