Air conditioning clutch issues
Old Aug 9, 2019 | 02:23 AM
PopHIz33's Avatar
PopHIz33
Unhappy Air conditioning clutch issues
So after I stalling a new compressor, condensor and drier. I filled the system with refrigerant and started the car to see if it was blowing cold air. The air coming out was blowing cold as I turned on the A/C and heard the clutch engage, but after having the A/C on for about 10-20 min the clutch didnt disengage. If I dont recall it should kick on/off periodically. I Was worried about burning the compressor out so I turned it off.
I haven't replaced the A/C pressure switch or expansion valve (not looking forward to ripping dash out). Hoping for just the A/C switch needs to be replaced.
Any information as to why it stays engage would be helpful. 🤙🏽
Old Aug 9, 2019 | 07:41 AM
rustyschopshop's Avatar
rustyschopshop
Did you use a vaccum to suck the system down before filling with refrigerant?
Old Aug 9, 2019 | 07:55 AM
iideadeyeii's Avatar
iideadeyeii
The clutch cycles when there isn't enough pressure
Old Aug 9, 2019 | 02:35 PM
PopHIz33's Avatar
PopHIz33
I used a professional A/C machine, and vaccumed the system before putting refrigerant inside and the gauges never displayed any leaks.
Old Aug 9, 2019 | 02:38 PM
PopHIz33's Avatar
PopHIz33
If the system dosent cycle off then should I replace the Pressure sensor switch on the drier?
Old Aug 12, 2019 | 06:14 AM
iideadeyeii
Are you saying the clutch is still engaged when the A/C is off? The clutch is not suppose to cycle when the A/C is on.
Old Aug 12, 2019 | 10:50 AM
masterjr33's Avatar
masterjr33
#1 are you saying the compressor runs with the A/C set OFF?
#2 whats pressure readings and ambient temp?
some times low charged systems the compressor stays on way to long..
Old Aug 13, 2019 | 08:38 PM
PopHIz33's Avatar
PopHIz33
No the clutch isn't engaged when I have the A/C off. My original question was when I have the A/C on and how the clutch operates.
I figured the clutch on the compressor is meant to cycle on/off when I have my A/C on because my other cars do so.
So is it normal for the clutch on 350z A/C compressor always stay engaged when you have the A/C button toggled on?
Old Aug 14, 2019 | 05:14 AM
iideadeyeii
hndumafia
May 8, 2021 12:59 PM
PopHIz33
Aug 6, 2019 02:58 PM
Stetson45
May 23, 2017 07:59 PM
shanex1112
Mar 21, 2016 05:32 AM
