Engine swap check list.
Old Aug 16, 2019 | 07:16 AM
masterjr33's Avatar
masterjr33
Default Engine swap check list.
Replacing the engine in my 05 Revup car with a LKQ low mileage engine at a local shop.
trying to get together everything i would need or any performance benefits while there.
I have a new engine seal kit and new spark plugs.
coolant. oil . filter.
Putting in a new radiator while it is out from napa. just a stock replacement.
I already have test pipes and a brand new clutch in the car.
I will have the bumper painted while it is off.
any thing else you can think of.
anything else to do while im there.
Old Aug 16, 2019 | 07:21 AM
iideadeyeii's Avatar
iideadeyeii
If you wanted longtubes this would be the time
Old Aug 16, 2019 | 08:57 AM
bealljk's Avatar
bealljk
would consider...?
throw-out bearing if it wasn't done earlier.
new trans fluid, you might have to do this if it spills out during re-assembly/re-installation
flush/fill the power steering while the motor is out
flush/fill the clutch cylinders
and you'll want to add a turbo!!
Old Aug 16, 2019 | 11:36 AM
masterjr33's Avatar
masterjr33
Would love to try some. but 1000$ for 5-10 HP doesnt seem worth it at this point.
I do have test pipes and a y pipe already.
Old Aug 16, 2019 | 11:37 AM
masterjr33's Avatar
masterjr33
Originally Posted by bealljk
would consider...?
New throw out bearing clutch and flywheel about 1 month ago.
Good call on trans fluid. i'll see about that.
and the clutch cylinder. it was getting grumpy when hot any ways.
Old Aug 17, 2019 | 10:40 PM
NiLL's Avatar
NiLL
ISRs are 500 bucks. and its 5-10HP on a stock car. You get more out of it the more you do to it. Also Peak isnt all the matters.
Die Go
Jun 7, 2017 03:35 AM
ByThaBay
Dec 11, 2012 03:38 AM
shawn17ths
Oct 8, 2005 08:29 PM
superstuddc27
Oct 4, 2004 02:44 PM
