2007 350z clutch problem
Old Oct 8, 2019 | 07:23 PM
Bryanp11's Avatar
Bryanp11
Default 2007 350z clutch problem
So today I was driving my car when I put it in first gear and the clutch was all the way out and I gave it gas but the car didn’t move at all it was as if I had the clutch in or it was in neutral, it only rev the engine but no movement, the clutch pedal also felt more stiff then usual. Any thoughts of what the problem can be ?
heres a video where the car is in gear and I release the clutch all the way out with no gas and the car doesn’t even stall
Old Oct 8, 2019 | 07:41 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Most likely the infamous and well documented CSC failure.
Old Oct 8, 2019 | 07:48 PM
Bryanp11's Avatar
Bryanp11
Do you think it could be the clutch as well ..?
Old Oct 9, 2019 | 03:46 AM
travlee's Avatar
travlee
Master
my money is on the csc, but if you are going to drop the trans to replace that might as well do the clutch while you are in there.... btw, do NOT replace the csc with oem, it will fail again
JasonCA
Jan 1, 2016 10:13 PM
Igalaviz17
Sep 25, 2013 10:42 AM
Igalaviz17
Sep 25, 2013 08:45 AM
jetnoirZ
Sep 13, 2007 07:07 PM
JasonCA
Jun 12, 2007 02:28 AM
