Brake disc removal problems
Not sure how a gear puller is going to help when it's the bolts on the studs that can't be undone. If they were loosened and the spacer was still stuck on then maybe. But the basic idiocy of this scenario seems to be the bolt/nuts.
I'm actually surprised the nuts haven't stripped/rounded throughout this affair.
I had the exactly same problem when upgrading to brembos past week. The soolution that i found was to use a small torch to heat up the bolt/nut and the using a nut remover hammering with a rubber mallet.
https://www.harborfreight.com/electr...CABEgLGaPD_BwE
350Z/370Z Tech Moderator
sicilianoNYC
Aug 5, 2004 02:19 PM
