Tools needed
Old Nov 11, 2019 | 09:04 PM
epenbecks's Avatar
epenbecks
Default Tools needed
Dumb story and questions.
I was trying to install my new coilover but failed because i don't have the "right" tools. I'm using my wrench set that i bought long time ago. It's not a good brand for sure. The #12 ended up crack. The #17 doesn't look strong enough because i see it flexing when i trying to use it. So the questions are, is wd40 can help removing the bolt easier? Any recommend brand for wrench set that i can find it easy at autozone or home depot? Or should i just rent it from home depot?
Thanks before
Old Nov 11, 2019 | 10:10 PM
bealljk's Avatar
bealljk
What exactly is the problem?
try PB Blaster...
Old Nov 12, 2019 | 03:12 AM
Heel Til I Die's Avatar
Heel Til I Die
If you work on your car a lot, it's probably a good idea to invest in a quality set of tools so you don't have to rent in the future. Get a good breaker bar for those seized bolts and some sockets that have a lifetime warranty. If you're going to HD, I think Husky tools have a warranty on them. Or, you can get some higher tier like snap-on or Mac.
Old Nov 12, 2019 | 03:28 AM
travlee's Avatar
travlee
Master
i have always favored impact sockets
Old Nov 12, 2019 | 05:32 AM
LexD's Avatar
LexD
Don't try this with only wrenches, you need to re-torque fasteners when putting humpty dumpty back together.
Harbor Freight sockets (maybe a torque wrench too!) will be your lowest priced option and not the worst in terms of quality.
As above, if you're working on suspension and have access to a compressor / impact gun the impact sockets should be your choice.
Old Nov 12, 2019 | 06:43 AM
Bak3rme's Avatar
Bak3rme
use some leverage man. put a pipe on that wrench and sucker that bolt off!
Old Nov 12, 2019 | 07:12 AM
travlee's Avatar
travlee
Master
the harbor freight low profile jack is dual purpose....... jack up the car, and use the handle as the pipe bak3rme mentions
Old Nov 12, 2019 | 09:05 AM
iideadeyeii's Avatar
iideadeyeii
This is probably a good start https://www.homedepot.com/p/Husky-Me...0MTS/301653450 and you can work up from there.
Old Nov 12, 2019 | 09:22 AM
Dent350Z's Avatar
Dent350Z
If your wrench is really flexing don't add more leverage! But a decent set of sockets and wrenches go a long way to making the job easier. Lube, leverage and heat can help loosen stubborn fasteners too.
Old Nov 12, 2019 | 11:44 AM
epenbecks's Avatar
epenbecks
try PB Blaster...
yes i'll buy pb blaster too.
i have that jack and i'll see if that handle can help me.
this thing looks promising. I order it right away and pick it up later. Thanks a lot man. Now i don't have to worry if the tools break
yeah i'll see the torque wrench to put them back together.
Thanks a lot for all the help guys
Old Dec 9, 2019 | 08:05 AM
epenbecks's Avatar
epenbecks
Just want to give some update here.
Yes pb blaster, jack handle and those husky tools are very helpfull.
I finally install my tein coilover last weekend but... except the front left
The #12 nut on top was broken and rounded. So i'll just gonna go to shop to install the last corner, do allignment and share the picture here
Old Dec 9, 2019 | 08:21 AM
travlee's Avatar
travlee
Master
this is all you need to get that nut off
https://www.harborfreight.com/9-pc-3...set-67894.html
Old Dec 9, 2019 | 08:25 AM
terrasmak's Avatar
Stay far away from Harbor Freight for sockets, wrenches and screwdrivers
Old Dec 9, 2019 | 08:29 AM
travlee's Avatar
travlee
Master
are they quality, no not at all. do they work in a pinch, yep. especially (to me) something i may only use once
Old Dec 9, 2019 | 08:41 AM
epenbecks's Avatar
epenbecks
Thanks for the info. I also found this at oreilly and AZ, but weird, they don't have #12 on the sets i found.
I hope later the shop not gonna charge me too much just to install one corner. I can't wait to drive the Z again.
Old Dec 9, 2019 | 09:02 AM
terrasmak's Avatar
they have a time and place, stripping screws , bolts and nuts is not fun.
Old Dec 9, 2019 | 09:14 AM
travlee's Avatar
travlee
Master
true story....
Boneout JZA80
Southern California
21
Jun 3, 2009 03:04 PM
go_speed_engy
Jul 14, 2008 01:33 PM
Mixturepinoy
North West
Jun 5, 2007 09:32 PM
Lancaster
Dec 12, 2005 05:05 PM
sillyhenwee
Mar 30, 2005 02:33 PM
