05 Wiring harness replacement
Old Feb 3, 2020 | 05:08 PM
SeanZDennis's Avatar
SeanZDennis
Default 05 Wiring harness replacement
I’ve got an 05 35th anniversary edition 350z and I’m replacing the engine bay wiring harness. I bought a replacement harness from an 06 (DE) and I was wondering if this is a direct replacement. Thank you.
Old Feb 3, 2020 | 06:06 PM
Spike100's Avatar
Spike100
Yes, I believe it is the same (2003, 2004, 2005,and 2006).
Old Feb 3, 2020 | 06:20 PM
bealljk's Avatar
bealljk
what transmission do you run?
what transmission did the donor harness come from?
Old Feb 3, 2020 | 06:33 PM
SeanZDennis
both are manuals.
Old Feb 3, 2020 | 07:03 PM
Spike100's Avatar
Spike100
Originally Posted by SeanZDennis
both are manuals.
Then, I think you are still OK. The harnesses sold online are labeled for 2003 to 2006.
Old Feb 3, 2020 | 07:41 PM
bealljk's Avatar
bealljk
Youre good
Just be careful as the wire colors used in your 2006 donor harness may not match your 2005 factory service manual - not saying they are the same / not saying they are different - just saying they could be different and dont assume either way.
if you want a good exercise that'll help you learn the harness is to check continuity between a given connector and it's associated pin on the big ECU connector...If you do this, you should label each connector - it will really help with the coils and injector clips.
BlackOhfour
Oct 2, 2012 09:01 PM
frostyrock7c
Jun 29, 2005 07:27 PM
