How to remove wire clamps?
Old 05-11-2020, 04:07 PM
ecop_z33
ecop_z33's Avatar
Default How to remove wire clamps?
Beginning my first job on my Z and I've never worked on the VQs before. When I go to remove the strut bar the last bolt on the left side is being blocked by this clamp mechanism holding the positive terminal wire in place. How do I remove the clamp so I can get to the final bolt in order to remove the strut bar?
Old 05-11-2020, 04:33 PM
travlee
Master
travlee's Avatar
Received 9,126 Likes on 6,579 Posts
Screwdriver
Old 05-11-2020, 04:36 PM
ecop_z33
ecop_z33's Avatar
Originally Posted by travlee
Screwdriver
yeah I know, tried pushing it in like the camshaft position sensor but wouldn’t release. Where exactly do I apply pressure to release it? Thanks for the response.
Old 05-11-2020, 04:42 PM
travlee
Master
travlee's Avatar
It comes loose in the red area, then just move the loom out of the way
Old 05-11-2020, 06:33 PM
Zelduh
Zelduh's Avatar
If you look at the side of the square on the loom clamp, they have opposing triangles that lock when pushed together. Gently pry on the upper side and it'll unhook from the lower.
Or, wiggle the vertical plastic mount & it'll pop off the metal anchor tab and allow you room to get to the bolt.
ecop_z33 (05-11-2020)
Old 05-11-2020, 07:25 PM
ecop_z33
ecop_z33's Avatar
Thanks bro I got it easily I feel dumb now 🤣
Old 05-12-2020, 12:53 PM
calvin.w
calvin.w's Avatar
Shiiiiid I just broke mine off. If it's not gonna hurt anything, it can be broken!
ecop_z33 (05-21-2020)
Old 05-15-2020, 06:46 PM
Zelduh
Zelduh's Avatar
Nah, not at all, they can be aggravating as hell.
These things are all 11-17 years old, time & temps aren't on your side. You can make a strain relief with appropriately sized zip ties and attention to detail so they don't stick out.
Old 05-16-2020, 09:59 PM
zwei_the_c
zwei_the_c's Avatar
OMG, don't get me started on how annoying the headlights connectors pieces are... maddening!
The following 2 users liked this post by zwei_the_c:
ecop_z33 (05-21-2020), Zelduh (05-17-2020)
FarSeide
06-03-2015 06:00 AM
lukep90
04-23-2008 07:29 PM
turtle1678
02-16-2008 08:30 AM
Beeker
10-24-2005 08:32 AM
SmO69
06-19-2005 05:41 PM
Quick Reply: How to remove wire clamps?
