Deadful 5th gear grind
Old Jun 29, 2020 | 07:20 AM
Franknbeans's Avatar
Franknbeans
Thumbs down Deadful 5th gear grind
So my 5th gear always had a small grind from 6th to 5th. Not a big deal, I just slow shift into 5th when cruising. But now it is grinding from 4th to 5th. My issue is, I touch the bottom end of 5th gear when on the track so I can't slow shift into it.
My question is, Do I just purchase another transmission and install it or pull mine to get the syncros fixed?
2005, Anniversary Edition, Manual, RevUp.
Old Jun 29, 2020 | 09:03 AM
HRMoneyPit's Avatar
HRMoneyPit
Used trans
Old Jun 29, 2020 | 09:04 AM
Franknbeans
So how would I know if the used one has the same issue?
Old Jun 29, 2020 | 10:22 AM
iideadeyeii's Avatar
iideadeyeii
Buy from a reliable seller, but my Z has been grinding 2-3rd on non-rpm matched shifts for 9 years. Hasn't broke yet with about 300whp
Old Jun 29, 2020 | 10:34 AM
Franknbeans
Do you also track your car?
Old Jun 29, 2020 | 10:44 AM
iideadeyeii
No. Has only seen about 20 runs on a 1/4mile. I get your point though if you are grinding it weekly
Old Jun 29, 2020 | 10:49 AM
Franknbeans
yeah, mine is more of a dual monthly track car than anything else.
Old Jun 29, 2020 | 11:14 AM
qreshadow's Avatar
qreshadow
I think it would cost more to rebuild your current trans unless, of course you do it yourself and have the tools. I'd hold off as long as you can but if it really bothers you, then I'd buy a new trans from Z1 for about 1,800$. I'm facing the same decision myself but its not bothering me 1,800$ worth yet .
Old Jun 29, 2020 | 02:27 PM
dkmura's Avatar
dkmura
General & DIY Moderator
What kind of tranny lube have you been using?
Old Jun 29, 2020 | 07:24 PM
Franknbeans
Just replaced it last year with OEM Nissan fluid. Did the tranny and rear end.
Old Jun 29, 2020 | 08:07 PM
dkmura's Avatar
dkmura
The tranny and rear diff use different lubricants. Using Nissan GL-5 75-90W fluid in the tranny will severely degrade syncros and other parts.
Old Jun 30, 2020 | 04:19 AM
Franknbeans
I didn't use the same fluid in both the tranny and diff.
Old Jun 30, 2020 | 04:28 AM
Franknbeans
double post
Old Jun 30, 2020 | 04:53 AM
dkmura's Avatar
dkmura
Can't hurt to ty Redline MT85 in your tranny before replacing it.
Old Jun 30, 2020 | 06:39 AM
thekinn's Avatar
thekinn
I had the same issue, tried the magical different trans fluids and it did not resolve the problem. I got mine replaced with a brand new CD00A @ Dynosty. Took the opportunity to replace clutch, flywheel, master, and slave cylinders too... should be good for another 10 years.
Old Jul 6, 2020 | 07:29 AM
Bak3rme's Avatar
Bak3rme
Frank I'm in the same boat as you. I am grinding 3rd to 4th and more recently 4 to 5th. I can baby shift it into those gears with a 50/50 shot of not grinding but when I'm on track baby shifting doesn't even come into mind hauling down the straights. The Z now only goes to and from the track as well as on track time so it gets under 5k miles a year. It sees 2-3 trackdays a month in the good New England months. Its been going on for about 2 years with 4th to 5th grinds new since last year. I had redline in the tranny for 3 years and putting in new fluids does not band-aid the grind any bit. Since I'm an 03' I don't have the CD009 transmission and am going to keep going until this one completely fails.
I often check facebook marketplace for used CD009 transmissions and see them ranging from $600-900 in the New England area. A brand new one from Z1 is 1.7k which I don't think is really worth it for me. I'll buy a used one when the time comes.
Old Jul 6, 2020 | 10:41 AM
Franknbeans
Thanks for the info. Seems that we do about the same with our Z's. I'll drive mine once in a while around town but I have a lot of other rides too.
I'll keep grinding until it's gone then... And go from there. LOL
Old Jul 23, 2020 | 07:02 PM
BaggySocks's Avatar
BaggySocks
I am new here and have an 04 350z with only 50k miles on it. I have a grinding issue when shifting from 4th to 5th as well when fast shifting. With how low the miles are on my car is there anything else I can check before replacing the transmission?
Old Jul 23, 2020 | 07:03 PM
Franknbeans
Not really. It was a synco issue from the factory.
Old Jul 23, 2020 | 07:45 PM
dkmura's Avatar
dkmura
Yes- learn how to heel-toe downshift and rev match. It really does take a lot of stress off the syncros and is a delight to perform.
