350z revup heads onto non revup block
Old Jun 29, 2020 | 05:11 PM
Kspinazzola's Avatar
Kspinazzola
Default 350z revup heads onto non revup block
Well guys I’m back for more advice.
I’m have a 06 Z revup 6mt motor has rod knock
im swapping the revup heads onto a nonrevup block I got.
now I’m trying to keep cost down, should I bother sending the heads to a machine shop? If I had a blown head gasket I would of course but that’s not the case. Are these heads known to warp or crack? Would you bother doing it if it was your car?
Old Jun 29, 2020 | 09:46 PM
icer5160's Avatar
icer5160
I would do it just to get the valve stem seals replaced/upgraded, they are known to start leaking on high mileage engines. Should be an affordable proposition seeing as you have the heads removed already. A good shop would/should also check the heads for warping or cracks, bent valves, etc.. To my knowledge, VQ35s aren't known for warping/cracking heads unless the engine is severely overheated.
-Icer
Old Jun 29, 2020 | 10:15 PM
Kspinazzola
-Icer
that was my understanding as well but I figured I would check before I do anything. Thank you for the input I appreciate it.
Old Sep 9, 2024 | 08:52 AM
DKVN's Avatar
DKVN
Hi everyone
my car is 2003 nissan 350z vq35de
i have short block revup block, i want to put on non-revup engine because the block is dead and I have spare revup short block here
anything that I have to take care, thanks
dorrifto
NA Builds
Sep 6, 2012 07:13 PM
pcressey
Wanted
Apr 28, 2011 07:57 AM
Nismo350ZRT
Jun 2, 2008 08:17 AM
KPierson
Jan 23, 2008 10:42 PM
