2003 350z low/no power
Old Aug 26, 2020 | 08:09 PM
ineedhelpbroo's Avatar
ineedhelpbroo
Default 2003 350z low/no power
so my z hasnt been starting the last few days, it will start when i jump it, so i replaced the battery. same issue. ive cleaned and tightened the terminals. ive tested it and its getting over a 12v connection. it started of with a fast ticking sound when i tried to crank it over, but after replacing the battery the dash lights dont even come on. any suggestions?
Old Aug 26, 2020 | 09:30 PM
mr. sparco's Avatar
mr. sparco
I would check: fuses, random ground causing drain, starter, and alternator next.
Old Aug 27, 2020 | 12:16 PM
icer5160's Avatar
icer5160
As sparco said. Start with checking fuses, and make sure the engine block ground strap is in good shape. The starter completes it's circuit through the block, it does not have a dedicated ground wire.
-icer
Old Sep 29, 2020 | 02:46 PM
adammickel's Avatar
adammickel
If you're going from a BMW to a 350z, you're probably going to be disappointed in the interior as some consider it "cheap". They're not the best if you're doing a lot of stop-and-go driving but other than that they're a fine car.
Old Sep 30, 2020 | 06:54 PM
atjames56's Avatar
atjames56
-icer
limp mode, it may be in limp mode. I'm not super familiar so ask or Google it.
93Nelson
Dec 16, 2022 12:22 PM
Martinezjr4
Oct 16, 2021 09:58 AM
Roadmanz33
Jul 22, 2019 08:31 AM
Bak3rme
Nov 24, 2015 08:24 AM
SonneyC
Jan 9, 2008 04:47 PM
