Horn stopped working... Where to look to fix?
Old 10-03-2020, 09:49 AM
Bmsluite
Bmsluite's Avatar
Default Horn stopped working... Where to look to fix?
Well there was this old man I needed to pull up a bit at the light. Hit the horn and..... nothing. Went out. Had just worked this morning. Had to wait for the light to turn green to turn.
I have never had a horn stop working. I don't even know where to start looking to fix it.
Anybody have any suggestions?
I live in Chicago so I kind of need my horn going into the alley into my garage spot. Not to mention all the morons I need to honk at. I don't have any ambitions of being a patient driver who doesn't honk at people. I guess I could just angrily rev my engine but it's just not the same.
Old 10-03-2020, 11:26 AM
DarkZ03
DarkZ03's Avatar
I'd start at the horn connection, check for power and ground at theat point with someone pressing the horn button, then check to see if there is a horn fuse or relay. Last to check if all those are good would be connection in steering wheel and clock spring.
Old 10-03-2020, 12:11 PM
oldfreakingguy
oldfreakingguy's Avatar
On the other hand- might be the best that could happen to you.
Cool down. No one is going to move because of your big (mouth) horn.
Old 10-03-2020, 12:50 PM
Bmsluite
Bmsluite's Avatar
Fuse is good, no power to either horn. My guess is the clock spring thing with spinning harness in it went bad.
Old 10-03-2020, 01:38 PM
Bmsluite
Bmsluite's Avatar
Don't get testy bc you are old.just trying to add some humor to the post. You realize the REAL issue here is that if it is the clock spring, then the airbag won't work right?
Old 10-04-2020, 11:27 AM
oldfreakingguy
Not that old. Wasn't that humorous.
Old 10-04-2020, 01:45 PM
Bmsluite
Bmsluite's Avatar
Fixed it. Was the spiral cable
ry4ndavis
12-23-2014 11:57 AM
Carmeninchen
04-29-2014 01:40 PM
james-z33
10-05-2009 07:45 PM
Asad_A203
East Canada
02-04-2008 12:44 PM
Quick Reply: Horn stopped working... Where to look to fix?
