Exhaust Sound
Old Dec 11, 2020 | 11:50 AM
NATree50's Avatar
NATree50
Default Exhaust Sound
Just wanted to get on here real quick and see if this sound when I’m shifting is normal or not, the car does have invidia test pipes and is tuned, etc but I just figured I’d get some feedback on it, thanks! (It is an HR as well)
File Type: mov
Old Dec 11, 2020 | 12:22 PM
iideadeyeii's Avatar
iideadeyeii
Lol WTH. here's what my shifting sounds like with 3rd gear synchro grind
Old Dec 11, 2020 | 12:34 PM
NATree50's Avatar
NATree50
https://www.youtube.com/watch?v=Q-EZ...annel=Chevy69o
is that what you think it sounds like? I have different maps including a burble map and all that but It wasn’t on when I was racing, to me when im in the car it sounds more of a backfire it doesn’t necessarily sound like a grind to me it sounds like it’s coming from behind me which is where the exhaust is obviously but I’m sure you know more having been experiencing it, the car only does it when I’m at high rpms and I’m banging gears
Old Dec 14, 2020 | 06:20 AM
iideadeyeii
In my video you can kinda hear the same noise you have, but def not as loud. My shiftier is very tight. Is yours?
Old Dec 19, 2020 | 12:33 AM
NATree50's Avatar
NATree50
No. But as odd as it sounds I’m thinking it has to do with my injectors being maxed, my duty cycle is at 92% which is what my tuner told me and so what I’m assuming is that at high rpms and me shifting quickly it’s quickly trying to dump fuel and with them being ran harder than normal it’s almost trying to create a type of backfire from all of the built up compression it’s creating if that makes sense
Old Dec 19, 2020 | 07:56 AM
DarkZ03's Avatar
DarkZ03
You should not be running the car until you get bigger injectors, the max you want to run is 85%
Old Dec 19, 2020 | 06:02 PM
NATree50's Avatar
NATree50
Yeah I didn’t think to even ask about my duty cycle but I haven’t ran the car since and I don’t plan to until I swap injectors but I already have some picked out and I figured I’d go e as well when I do upgrade the injectors, appreciate the help!
Old Dec 19, 2020 | 07:38 PM
DarkZ03's Avatar
DarkZ03
No problem, just make sure you go big enough for ethanol since it uses a lot more fuel.
Old Dec 20, 2020 | 05:54 AM
travlee's Avatar
travlee
Master
Old Dec 20, 2020 | 11:26 AM
NATree50's Avatar
NATree50
yessir I planned on 600cc gtr injectors
Old Dec 20, 2020 | 04:00 PM
DarkZ03's Avatar
DarkZ03
what's your setup 600cc may not be enough, if you are going for 600cc might want to bump it to 1000cc.
Old Dec 21, 2020 | 04:37 PM
NATree50's Avatar
NATree50
just currently fbo and tuned, my tuner said the 1000cc would be pointless since I’m not running boost as of now that’s why he recommended the 600cc Injectors he has
Old Dec 21, 2020 | 09:33 PM
DarkZ03's Avatar
DarkZ03
Gotcha, I thought you were boosted for some reason.
galant350z
Mar 8, 2009 02:35 PM
KWIKZ
Mar 2, 2005 07:54 PM
