How to best preload suspension bushings?
Just replaced all the rear knuckle bushings with stiffer rubber ones.
Wondering what you guys this is the best way to preload the rear suspension before torqueing them down. With the front I could just lower onto ramps and then torque everything. Can't do that with the rear.
I've hear jacking up each corner off the suspension until it comes off the jack stands sort of works but isn't ideal. Was thinking of maybe trying to put doughnuts on the rear and then lowering it onto the ramps but I still think it would be too tight.
Any bright ideas?
Any bright ideas?
Which arms? The spring bucket arm? I don't think it can be done from the knuckle as it's such a crazy shape and I don't trust it to hold
Yes. I've done it on several different makes/models. You can also leave the jack under the pumpkin, just make sure it's not actually touching.
(OEM) FS/FT: Front and REar suspension with whiteline bushings
ZROCM
Suspension
Feb 19, 2019 09:28 AM
