hi how can I know if this transmission is cd009?????? thanks guys <3
Old Feb 5, 2021 | 08:12 PM
Juan LD2's Avatar
Juan LD2
Default hi how can I know if this transmission is cd009?????? thanks guys <3
Old Feb 6, 2021 | 02:01 PM
Heel Til I Die's Avatar
Heel Til I Die
Those stamps in your pictures CD0# 1 and CD0 #2 don't mean anything. Check the VIN on the plate at the bell housing. It should be in this general area towards the bottom.
Once you run the VIN, cross-reference it with the attached handy chart from Z1. If the production date is between 7/04-11/06, it's the CD009.
File Type: pdf
Old Feb 8, 2021 | 04:12 AM
Conway_160's Avatar
Conway_160
The real question is, why was the bellhousing cut off? If they did not weld it back on perfectly straight it will put un needed wear and tear on the tranny and crank.
Old Feb 8, 2021 | 04:23 AM
Juan LD2's Avatar
Juan LD2
Hii bro this is vin number , thanks brother ❤🙏
Old Feb 8, 2021 | 04:27 AM
Juan LD2's Avatar
Juan LD2
Hello brother, what do you mean by the cut? to the bell? the bell is for 2jz thank you very much for the support ❤🙏
Old Feb 8, 2021 | 04:34 AM
Juan LD2's Avatar
Juan LD2
The vin number is : JN1AZ34DX5M605672
Old Feb 8, 2021 | 03:21 PM
DarkZ03's Avatar
DarkZ03
You got the number then look it up yourself, a lot of people pay to get that info, we aren't giving it for free lol.
Old Feb 8, 2021 | 04:27 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
OP Showed prod date 1/2004; hence not a CD009. /thread
ipcheck
Nov 16, 2006 04:38 PM
