NEED Help - Clutch Bleeding Gone Wrong
Old Apr 11, 2021 | 04:55 PM
Franknbeans's Avatar
Franknbeans
Exclamation NEED Help - Clutch Bleeding Gone Wrong
Background:
I just replaced the clutch, pressure plate and flywheel.
When I went to put the slave cylinder back on I had to crack the bleeder open So I could get the push rod depressed to line up the mounting holes.
When I cracked the bleeder it was like a volcano went off. (I read after the fact that the system is always pressurized..??)
Now I can not get the system to hold pressure. The pedal just flaps to the floor.
I read several threads here about how you need to have positive pressure in the system when trying to build it up. So I bought on of those fluid transfer pumps so I could "force" fluid to the slave cylinder. This still isn't working. I can't seem to force the fluid with the pump in the system. If I crack the bleeder and try to pump the system i can barely get any fluid in. It feels like I can not get any fluid past the master cylinder. Yet, if I crack the bleeder with pressure in the system (from the pump, because the clutch pedal doesn't do anything.) I can get fluid out of the bleeder.
My only guess now is the brake master cylinder is bad????
Am I missing something, I've never had any issues like this with any clutch before.
Old Apr 12, 2021 | 03:50 AM
Conway_160's Avatar
Conway_160
Just need to bleed the clutch. You and a friend spend an hour or so bleeding the clutch. Try and find a piece of clear rubber hose so you can see the fluid coming out of the bleeder.
Old Apr 12, 2021 | 08:00 AM
Franknbeans
Fluid is coming out of the bleeder with no air in it. It has a little pressure now but the pedal won't return to the top all the way.
I decided to see if it was enough pressure to engage the clutch but now the DAMN CAR WON'T START.
Old Apr 12, 2021 | 08:37 AM
terrasmak's Avatar
It’s a pain, I always use a pressure bleeder. Position of the bleed port on the slave make it impossible to get the air out efficiently
Old Apr 12, 2021 | 09:39 AM
Franknbeans
Seems like I got some pressure in the clutch. It won't pop up to the top all the way but I heard this may be a bad spring.
Now, the car will not start. I used a NAPA flywheel, Clutch and PP. From what I heard it is most likely the crank angle sensor that is suppose to read a signal to start. Apparently it isn't seeing the proper signal to start the car.
Old Apr 13, 2021 | 06:27 AM
khnitz's Avatar
khnitz
5 Year Member
Could the flywheel be installed incorrectly? I thought I recall reading something about that affecting the crank position sensor and starting.
@terrasmak what fitting do you use on the Nissan for pressure bleeding? The reservoir cap doesn't tighten down enough for me to get a good seal with an adapter I made (I only use a few pounds of pressure with it....):
Old Apr 13, 2021 | 09:08 AM
terrasmak's Avatar
I use the motive bleeder with the cap for brakes. Someone just has to hold it the whole time, although I could probably figure out a better way to hold it on.
Old Apr 13, 2021 | 12:22 PM
350ZXLR's Avatar
350ZXLR
Default Could be the clutch pedal switch
Have you checked the clutch pedal position switch?
Old Apr 13, 2021 | 02:03 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
BF zip ties.
Regards,
King of Zip Ties
MagicPie
Oct 11, 2023 05:28 PM
Caseythefalcon
Jul 20, 2015 06:10 PM
Austin_z33
Aug 8, 2014 02:51 PM
kaze06
Feb 18, 2014 09:00 AM
Deedilus
Jun 8, 2011 06:16 AM
