I'm quoting from sites that say they are all the same engine, every site says they fit, I seen it done on YouTube videos, and talked about on websites, idk
you actually need 6500 posts on this forum to have enough research under your belt,
I just signed up to this forum specifically to say this
You sir are a ****ing idiot and clearly have no idea what youre talking about, youre babbling on like a 3 year old, shut the **** up your youtube videos if you opened your ears actually completely disproved your theory 😂 if you actually think you can just bolt up a fwd vq35de out of a maxima into a z or g chassis then it is clear you should never turn a spanner and keep talking **** on forums with info out of context from wiki and youtube, in conclusion Im currently going through a similar swap from z chassis to g chassis, if anyone has any pointers to look out for that would be amazing.
Just wanted to comment here in case anyone else is (like me) doing an engine swap and arriving to this old thread from Google. Do not listen to Subd, he is wrong. The other posters have correctly pointed out that you cannot drop in a FWD DE into a 350z.
I literally joined as a Nissan Technician who has changed more VQ35 DE’s specifically than you’ve probably seen on videos and real life combined that the FED and RWD are the exact same electronics heads valvetrain everything but the block casts are different 100% guaranteed a FWD block will NOT go in a RWD setup PERIOD. nor Vice Versa! I’ve seen it done but by people building a car not replacing an original engine anyone with welding knowledge could clearly fabricate a bracket to fit but SUBD it is NOT the same no matter what you think or post and by the way if your going to post videos to prove your point then post videos that Do Not contradict what your trying to say! Your videos even prove you completely wrong so get over it dude!
I have to replace my engine & was wondering if I could put a g35 coupe engine in a 350z? If so what do I have to change up in the car for that to be compatible?
were talking about the engine so keep in mind that the ecu is tuned differently, and depending on year, but keep in mind that revup and Nismo engines will be different,
