350Z 2004 Rev limiting @ 3,500 RPM
Old Aug 23, 2021 | 08:38 PM
ezcwb's Avatar
ezcwb
Default 350Z 2004 Rev limiting @ 3,500 RPM
PROBLEM:
Can't rev past 3,500 RPM on my Z, limiting ignition when not on gear (P or N, even when rolling). And when on any gear (D, +/-, or even Cruise) can't exceed 80mph.
The ignition cut is sharp! Exactly at 3,500, suggesting it's an electrical issue, and not mechanical/mixture etc... Even resembles an injection management control module.
Cruise Control works! Although the RPM limiter and 80mph max speed still applies (Which is a funny thing, making it relevant the the problem is not on pedal sensors) which also doesn't recall to low ECU voltage or anything else...
Old Aug 24, 2021 | 05:35 AM
seymore4's Avatar
seymore4
Professional
Has the car been tuned? It sounds like its stuck in a valet mode with an Uprev tune. Check for map switching, typically the performance map is #1
Old Aug 24, 2021 | 04:50 PM
ezcwb's Avatar
ezcwb
Default Works! Solved.
Just tried this, thank you. It works!
SET light on dash blinks according to map selected.
Old Aug 25, 2021 | 06:40 AM
seymore4's Avatar
seymore4
Professional
You tried all 5 maps?
Old Aug 25, 2021 | 04:38 PM
ezcwb's Avatar
ezcwb
Default Yes
Figured out there were more maps.
Also nothing better than a good night of sleep
Appreciate your help! Thanks for sharing.
Old Aug 25, 2021 | 04:45 PM
seymore4's Avatar
seymore4
Professional
Nice. You probably accidentally pushed the buttons in just the right order to activate the valet map
Old Aug 25, 2021 | 05:21 PM
travlee's Avatar
travlee
Master
Mine were in this order
1- 93 octane gas
2 - 89 octane gas
3- cruising....won't go over 80mph
4- valet
5- kill
Old Aug 28, 2021 | 08:58 AM
jv350z's Avatar
jv350z
Mine are
Map1= Tuned (91)
Map2= +timing w/2gal 100oct min
Map3= valet 2500 RPM 25 MPH
Map4= 0 RPM
Map5= Stock
redboostzed
Aug 20, 2021 08:40 AM
tprelude-370z
Jan 18, 2021 11:42 AM
Daserz33
Aug 30, 2016 02:16 AM
2ndchanceZ
Sep 20, 2013 04:10 PM
