Car Troubles
Old Sep 12, 2021 | 09:49 PM
SenpaiNodusMe's Avatar
SenpaiNodusMe
Default Car Troubles
Howdy,
So I was headed home in my 2006 350z got about 100k miles on it. Was doing a pull in 5th gear, hit about 110MPH and it suddenly went into neutral. I threw it back into 5th no issue then 6th and cruised on home with no issues at the time. Upon passing two lights and heading up hill, my car started to bog and as I was pulling into the parking lot it died. Starting the car, it bogs then dies, it tries to stay on but fails to do so. When I press the clutch down, it'll die sometimes but not all the time.
When I have it in first gear and try to go, it'll roll but I can't get anywhere with it, it just dies.
My battery is 100% fine, Bought it about 1-2 months ago voltage says it's good on the dash. Oil I need to change tomorrow due to me coming up to my mileage marker. My fuel is low it says about 46 DTE.
Would anyone happen to know the issues by any chance? Please help me out.
Old Sep 12, 2021 | 09:52 PM
SenpaiNodusMe
Video for reference:
Check engline lights are for Cat removal and Neutral safety switch which have been on since I bought the vehicle.
Old Sep 13, 2021 | 08:08 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Pull codes?
Old Sep 13, 2021 | 05:13 PM
Ponyryd's Avatar
Ponyryd
Start by putting some gas in it.
Old Sep 15, 2021 | 04:24 PM
Tomek350Z's Avatar
Tomek350Z
agreed, start with putting in fuel, I would not trust the DTE distance till empty completely
Old Sep 18, 2021 | 09:35 AM
jhc's Avatar
jhc
General & Tech Moderator
https://www.youtube.com/watch?v=k1P2...=TristanMiller
So Tristan-
The car bogs and you have a code for missing cats. Where is your question? Which cats to replace with? Should I get it tuned to run wo cats?Or why won't it go faster than 110mph?
Old Sep 19, 2021 | 05:11 AM
Bluez07's Avatar
Bluez07
Start with the simple stuff first. If there's a doubt about the fuel level, put some gas in it. Disconnect your negative battery cable afterwards to see if the ECU will reset, then try starting it. Keep us posted. Good luck.
z33Nick
Apr 5, 2022 07:19 PM
z33Nick
May 11, 2018 06:30 PM
GathrdOrphan
Jul 31, 2017 11:57 AM
AndyrewT
Jan 16, 2015 07:50 PM
ksuberk54
Aug 8, 2011 02:30 PM
