Transmission Problems
Old 03-18-2022, 03:28 PM
LeozinZ33
LeozinZ33's Avatar
Default Transmission Problems
2003 350z Manual
Okay so, I just rebuilt my engine but I'm having some transmission problems.
Those are:
- 1st gear and reverse popping/slipping out of gear when trying to roll out if given a rev of over 2.5kRPM
- Slight grind between gears.
- Rattling noise while car is on neutral, but it stops once clutch is pressed.
- While going up my driveway in reverse, you can hear a rattling noise coming from the transmission while reving the car. (it usually slips out when noise gets really loud)
All of this didn't happen before I swapped the engine. Trying my hardest to not have to rebuilt the transmission.
The attached video by the sounds of it, is the gears grinding, it stops once I put it in neutral and let go of clutch pedal.
File Type: mov
Old 03-21-2022, 04:27 PM
icer5160
icer5160's Avatar
The rattling noise is either the throw-out bearing (fairly normal) or the input shaft bearing (inside the trans case). Since you rebuilt the engine recently, I assume you installed a new flywheel, clutch and clutch components? Or did you re-use the old? You could have internal transmission problems. The 2003 MTs were notorious for synchro failures/issues.
-Icer
No Payne
09-12-2017 04:40 PM
SmokeUrZ
01-10-2014 06:23 AM
R-TuneZ
07-14-2008 11:24 AM
rocky16
03-25-2007 05:27 PM
knucklez
11-26-2006 01:00 PM
Quick Reply: Transmission Problems
