ABS System Issues
Old 05-01-2022, 06:37 PM
ChaoticShadows
ChaoticShadows's Avatar
Question ABS System Issues
I apologize in advance if this is in the wrong section I'm new to posting on the forum and was just looking for help. will move post if need be.
Was working on my z and its not mine originally. battery went bad, replaced it and now I'm having abs issues. looked through my engine bay and found that the fusible link in the engine compartment fuse box is missing one of the contacts. the whole car is a wiring nightmare and I've been working on fixing it but now that i replaced my battery i believe my abs module isn't working correctly. abs vdc brake and slip lights are on as well as speedo isn't working. just wondering if anyone knows what path these wires take or what else could be the cause as i also cant find where in the harness this fuse box connects and i also don't see it on any of the wiring harnesses I've seen on eBay when i went to just replace it. any help or direction is greatly appreciated. will include pictures at some point when i have the time or someone asks for specifics.
Old 05-02-2022, 06:43 AM
terrasmak's Avatar
Received 2,309 Likes on 1,663 Posts
Is this a salvaged car ?
Old 05-02-2022, 09:56 AM
ChaoticShadows
no it is not. Has a clean title and ran pretty good just has a history of electrical issues as the previous owner did some modification with minimal knowledge or effort.
Old 05-02-2022, 03:46 PM
dkmura
General & DIY Moderator
dkmura's Avatar
Received 1,304 Likes on 904 Posts
Do you have any idea what kind of modifications the previous owner did?
Also, have you scanned for trouble codes yet? The ANS system has its own recall section that might help pinpoint problems,
Old 05-02-2022, 04:59 PM
ChaoticShadows
I ran codes and it is stuff that goes wrong and it pulled codes for an abs system fuse in the engine bay. At least thats what i found in my research. Codes and symptoms are
P1564
P0037
P0051
P0031
p1212
P0500
U1001
some are oxy, airbag, and the fact that i have an aftermarket steering wheel.
Other symptoms are what i listed previosly as well as my head unit stopped working.
Neo Salenga
03-02-2020 01:55 AM
Bov82
11-10-2016 03:40 PM
jerseytaylor
11-29-2014 08:27 PM
Three5oZee
11-29-2007 08:16 PM
mberthia
08-29-2006 07:29 PM
Quick Reply: ABS System Issues
