Misfire?
Old 06-12-2022, 12:28 PM
Deo.z33
Deo.z33's Avatar
Default Misfire?
I’ve been at this problem for months. Car is at a lack of power when accelerating. And the exhaust sputtering idle but only one of the tips. The air coming from the exhaust is like thudding. I’ve changed spark plugs and ignition coils but it still happens. Could it be something with the exhaust system itself?
Rani Garner (06-14-2022)
Old 06-12-2022, 12:31 PM
travlee
Master
travlee's Avatar
Received 9,126 Likes on 6,579 Posts
Did you accidentally swap coils on drivers side?
Old 06-12-2022, 12:33 PM
Deo.z33
Deo.z33's Avatar
sorry I don’t understand?
Old 06-12-2022, 12:44 PM
Deo.z33
Deo.z33's Avatar
Left catalytic converter
Right catalytic converter. Suspecting it could be this?
Old 06-12-2022, 12:56 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,226 Likes on 1,595 Posts
^^^ 1st thing I thought of, how many miles?
Cats aren't hard to do, just hard to get to, you'll need several socket extensions, Liquid Wrench and maybe a cheater bar for leverage. To inspect remove 3 upper fasteners and drop so you view with a flashlight and small mirror. Gl!
Old 06-12-2022, 01:04 PM
Deo.z33
Deo.z33's Avatar
147k miles. many of my friends told me it’s my cats. I just have been hesitant to order the test pipes because they are $250 and what if they don’t solve the problem yk.
Old 06-12-2022, 01:18 PM
jhc
jhc's Avatar
Here's an idea- drop the top, inspect. If there's a brown or grey powdery buildup and you can't see the little squares they're clogged. If not, move on. At that point you remove completely, get the biggest screwdriver you have and a hammer. Either remove 1" off the top or gut completely. Reinstall. 0 cost, just time. It'll likely throw a CEL for cat efficiency so look up the O2 no fouler hack.
Old 06-12-2022, 01:24 PM
travlee
Master
travlee's Avatar
One drivers side, cylinder plugs can be swapped pretty easily.
Test pipes will need a tune or anti foulers. I would check wiring first
Old 06-12-2022, 06:27 PM
Deo.z33
Deo.z33's Avatar
aren’t they interchangeable. I have all new plugs.
Old 06-13-2022, 12:06 AM
travlee
Master
travlee's Avatar
Keep telling yourself that. Three and five get mixed up all the time
Old 06-13-2022, 04:29 AM
Deo.z33
Deo.z33's Avatar
ok I will look at them today after work to make sure I put them in the right place. Also it’s a cylinder 2 misfire.
Old 06-13-2022, 04:40 AM
travlee
Master
travlee's Avatar
then that prob isnt the issue. i would swap coil packs on 2 and 4, see if the issue follows it
jhc (06-13-2022)
Old 06-14-2022, 10:24 AM
Rani Garner
Rani Garner's Avatar
following. I have the same problem
CDNFairladyZ
04-05-2021 11:50 AM
kgb
09-15-2018 05:29 AM
FalseAngel
06-22-2017 11:45 AM
mestisoZ
11-13-2008 12:22 PM
redline350ZZ
11-19-2005 01:09 PM
Quick Reply: Misfire?
